1992 F150 question
Old Jan 29, 2021 | 08:59 AM
Billy Boone's Avatar
Billy Boone
1992 F150 question
I bought a 1992 f150 custom and noticed that it only has a single gas tank. Is this a rarity? I've never seen F150s of this era with single tanks. If i wanted to upgrade to a dual tank system how much of a pain would it be? It only has a 18 gal tank and it seems like I'm adding fuel all the time.
Old Jan 29, 2021 | 09:23 AM
WWR's Avatar
WWR
It'd be hassle but if you had a complete donor i guess you could do it. You'd need to swap the bed or be really good w body work for the second filler neck.
I'd run a Bronco tank in the rear. You'll need the tank, pump and pump hanger (which is typically integral with the pump itself on these OBS's). You'll have to relocate your spare and then can hang the tank with universal straps or the Bronco skidplate -- if the latter I'd still strap the tank and drop the skidplate 1/4" to create an air gap and thus no metal-on-metal rust.
edit: Bronco tank gets you 32 gals
Old Jan 29, 2021 | 11:25 AM
Billy Boone
Thank you for the reply, I will look at the bronco gas tank sounds like less of a headache.
Old Jan 29, 2021 | 11:32 AM
John Trent's Avatar
John Trent
i have a question i want to change the engine in my 95 f150 from a 5.0 to a 5.4 is it hard to do
Old Jan 29, 2021 | 02:22 PM
Stonedpony's Avatar
Stonedpony
Originally Posted by John Trent
I have a question I want to change the engine in my 95 f150 from a 5.0 to a 5.4 is it hard to do
Depends on how good of a mechanic you are and if you know someone at the bank and have some photos they want to be hidden or how deep your pocketbook is.
You will need a few things like a PCM for that engine, transmission that the PCM can talk to as it gets lonely talking just to the fuel and engine.
You will need the PCM that does not have the anti-theft system (97-98 or look on this site for the company that deletes that on a PCM) and a fuel pump that puts out around 60psi for the engine. Have a return line for the fuel to the tank, upgraded EGR system, wiring harness for all of this, Change your exhaust pipe at the hookup to the exhaust manifold. Yep, it can be done, just a few things that you will have to change. Up to you if it is worth the trouble and cost as this is just a small list.
Old Feb 9, 2021 | 12:14 PM
John Trent's Avatar
John Trent
well i think i will just rebuild what i have or find a donor truck
Old Feb 10, 2021 | 10:45 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Did you mean, 5.8 instead of 5.4? The 5.4 didnt come out until 97 in trucks and had OBDII, is reason for such a hi price, to change your truck over.
Old Feb 12, 2021 | 04:22 AM
John Trent's Avatar
John Trent
yes i did is it not as bad as the 5.4
Old Feb 12, 2021 | 07:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
In that case to go from a 5.0L to a 5.8L it is almost as easy as remove and replace. The exhaust y pipe is different between the two.
Plenty of threads addressing this swap.
Old Feb 12, 2021 | 11:20 AM
John Trent's Avatar
John Trent
o ok cool that helps
Roy C
Mar 6, 2010 12:21 AM
TallPaul
Aug 21, 2008 11:34 AM
Towmanjbo
Jun 9, 2007 03:56 PM
fordtbird1995
May 11, 2007 08:48 AM
davidsca
Sep 4, 2006 09:49 PM
