Speed sensor question
Old Jan 28, 2021 | 09:08 PM
CurtLarson's Avatar
CurtLarson
On an 88 f250, is the speed sensor on the rear axle for the ecm or the abs? I’m using the engine, trans, t case and wiring from one for a truck project and wondering if the ecm will miss that. Or can a just use the speed sensor for the cruise on the speedo output?
Old Jan 29, 2021 | 04:32 AM
EPNCSU2006's Avatar
EPNCSU2006
My understanding is the rear axle speed sensor is only used for RABS on a '88.
Old Jan 29, 2021 | 05:43 AM
CurtLarson's Avatar
CurtLarson
That’s what I was hoping to hear!
Old Jan 30, 2021 | 06:25 AM
tjc transport's Avatar
tjc transport
i ain't rite
88 used transmission/transfer case tailshaft speed sensors only.
Old Jan 30, 2021 | 08:47 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Correct. The sensor in the rear differential is only used by the ABS.
My ‘87 Bronco had a sensor in the 8.8 axle for the RABS. When the bearings failed I deleted it for a 9” with lower gears. The speedometer is driven off the transmission/ transfer case.
Old Jan 30, 2021 | 02:06 PM
rla2005's Avatar
rla2005
I do not recall when RABS was a standard feature.....
Old Jan 30, 2021 | 02:12 PM
tjc transport
i ain't rite
load weight sensor RABS started in 85 or 86.
electronic RABS started in 87.,,, and was pretty much useless.
4 wheel ABS started in 99 on ford pickups.
Old Jan 30, 2021 | 02:18 PM
rla2005's Avatar
rla2005
Thanks Tom!
Old Jan 30, 2021 | 06:11 PM
My4Fordtrucks
I have had it activate but no it doesn’t work like more modern systems.
Four wheel ABS was available on Broncos. The ‘94 had it.
Old Jan 30, 2021 | 06:43 PM
CurtLarson's Avatar
CurtLarson
I appreciate the help!! Thank you!!!
Old Jan 30, 2021 | 07:08 PM
Smokerr's Avatar
Smokerr
Yep, never had it do anything on the 95
I finally got it to work on the 95 Bronco when we got Blizzak tires, even studded did not have enough grip to activate.
Old Jan 31, 2021 | 07:30 AM
tjc transport
i ain't rite
4 wheel ABS was an option before 99, starting in 94-95. i think.
it became standard equipment in 99
achyness
Mar 11, 2015 02:58 PM
ghunt
Apr 5, 2008 12:49 AM
Mormakil
Aerostar
Mar 29, 2006 05:13 PM
lwpman
Apr 28, 2004 08:41 PM
