Sponsored by: Real Truck
Desperate for help with map light stuck on
Old Jan 27, 2021 | 08:07 PM
SamHenson's Avatar
SamHenson
Alright guys, I'm at my wit's end with this. Been having intermittent problems with my map light just coming on randomly, usually while parked, and ONLY in cold weather. It also makes a chime, like they key is left in. I tried the WD40 trick on all the hinges, and the switch. No help. Then my buddy bought a really nice code reader, and finally pulled a code for driver door ajar. So I replaced the switch. Problem went away for a couple months. Just started again today. Gonna have him pull the codes again tomorrow. Also, when I tap the dash over the instrument cluster, I can get it to stop. So far, that's the only way to get it to stop after it starts, a quick slap on the dash. Desperate for suggestions. New instrument cluster?
it's an 05 F250, with a 5.4l, fyi. I have a video of symptoms, but can't post it.
Old Jan 27, 2021 | 09:17 PM
muhford's Avatar
muhford
Carefully check all the solder joints on the instrument cluster. My old truck's odometer would only work if you slapped the dash. Turned out to be a bad solder connection.
Old Jan 27, 2021 | 09:27 PM
SamHenson's Avatar
SamHenson
Thanks Muhford. I'll try that. The backlight on my fuel gauge also only works when you tap on the dash, so that might actually track. Did you just re-solder the connection?
Old Jan 27, 2021 | 09:28 PM
muhford's Avatar
muhford
Yup. Just touched it up and it worked fine.
trukerdanz
1983 - 2012 Ranger & B-Series
Oct 14, 2019 05:55 PM
Bigtruc
Mar 9, 2018 07:14 PM
Scerb
Mar 29, 2017 05:21 PM
hurst1979olds
Oct 26, 2016 08:36 PM
