View Poll Results: Is my pcm bad or is it something else like transmission or sparkplugs
Is it the CATYLIC converter
100.00%
The pcm
0%
Or misfire
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
2006 Ford expedition pcm problems maybe
Old Jan 26, 2021 | 06:09 PM
jjmoney11's Avatar
jjmoney11
My truck has problems when I'm giving it gas up to about like 2000 rpms, it starts and sputters and sounds like the exhaust gas can't go through the cataylic converter. After I get the transmission to shift into second gear the sputtering goes away a little and can drive it and the transmission was giving me travel shifting now might be my pcm I need some advice
Old Jan 26, 2021 | 06:39 PM
ford390gashog's Avatar
ford390gashog
I am going with multiple misfires. What are the current codes and what is the condition of the plugs and coils?
Lowercase is perfect....
Old Jan 26, 2021 | 06:46 PM
jjmoney11's Avatar
jjmoney11
Expedition not running right
The codes are reading P0430 catylust system efficiency below threshold bank 2 and P0010 camshaft position actuator circuit open bank 1 and P0720 output speed sensor circuit one P2106 throttle actuator control system forced limited power please help me the best you can
Old Jan 27, 2021 | 03:54 PM
ford390gashog
Well that means random misfires, plugged cats and it needs a full timing job including phasers and actuators. Does the engine make the distinct diesel tick noise at idle?
Old Jan 27, 2021 | 10:00 PM
jjmoney11's Avatar
jjmoney11
No it doesn't tap or knock at all I reset the codes today and took it out around the block and I drove like 300 feet and I couldn't move anywhere but the truck didn't die I shut it off for 5 minutes then started it and got home back around the block barely the trans will not grab at all and there is no lights coming on giving me codes
Old Feb 2, 2021 | 08:58 AM
alloro's Avatar
alloro
FYI, some codes won't set until there have been two complete cool down and warm up cycles.
Erick Gonzalez
Modular V8 (4.6L, 5.4L)
Mar 28, 2017 12:56 PM
jrigsby
Maryland Chapter
Mar 10, 2015 09:40 AM
danny2313
Jan 9, 2014 01:42 PM
kailor
Apr 6, 2008 06:09 PM
