T86 Overdrive
Old Jan 25, 2021 | 06:52 PM
1966F100SC's Avatar
1966F100SC
T86 Overdrive
I have come across two items and have made them different threads. I have on the table a T86 3spd with overdrive available to purchase. It came out of a 56 with a y block. I have a 66 with an FE and 3sped 3.03. Would this be a direct swap or are bolt patterns different? Are the tail shafts different lengths resulting in a driveshaft change
Old Jan 25, 2021 | 07:45 PM
85e150's Avatar
85e150
T86 will have a square pattern where it bolts to the bell.
'66 FE will have a rectangular pattern for the bell to trans.
Some transmissions will accept both, but that's usually the later, wider transmissions.
It's easy to put the newer trans on the older engine. Going the other way looks to be a DIY project.
Old Jan 25, 2021 | 08:40 PM
1966F100SC's Avatar
1966F100SC
Okay thank you. I won’t be following through with this just wanted to see if it’s an easy doable option.
Old Jan 26, 2021 | 08:59 AM
hiball3985's Avatar
hiball3985
The earlier trans will have a longer input shaft. It will also have a larger bearing retainer collar were the throw out bearing rides and needs a different throw out bearing that won't work with the 66 bell housing clutch arm. I would forget it.
Old Jan 26, 2021 | 09:13 AM
6t6merc's Avatar
6t6merc
There is a later T-86 (T-85 is the car type, right?) that will fit. A friend has a complete setup that was attached to a 360, in what he thinks was the last model year it was available, maybe a '68. It is a rather complicated swap.
Eric
Tooreal11
36
Feb 10, 2020 02:16 PM
TBird Larry
Aug 16, 2014 05:54 PM
48prerunner
Aug 25, 2011 10:18 AM
wmrobert
Oct 25, 2005 01:16 AM
Broomfieldbum
Sep 14, 2005 05:17 PM
