Need An Advice
Old Oct 26, 2003 | 01:21 AM
baja1's Avatar
baja1
Need An Advice
I got an a off road racing truck, but we are havin problens with the heads gaskets, we changed 3 times and still water in the engine and puking out thru radiator cap. I need to know it i have to get a new block or new heads cylinders?
Old Oct 26, 2003 | 01:37 AM
Superdave's Avatar
Superdave
baja1
Sounds like you need to have your block and or heads inspected for cracks or warpage by a competent machinist.
They can then lead you in the direction you need to go repair wise.
Old Oct 26, 2003 | 01:20 AM
LxMan1's Avatar
LxMan1
Yep, have the machine shop magnaflux the block and heads for cracks. Then have them check the heads and block deck to make sure that the surfaces are true and do not need milled.
Jimmy
Old Nov 2, 2003 | 10:32 PM
baja1's Avatar
baja1
thanks guys,
