Sponsored by: Real Truck
6.0 smoking problem
Old Jan 25, 2021 | 01:05 PM
Bbg's Avatar
Bbg
6.0 smoking problem
Alright guys, coming to you because I’m completely stumped. Truck has been smoking, less at idle more when initially taking off from a stop or giving it more gas. It’s like it slowly builds up more smoke when I’m driving it, but when I park it and let it idle it slowly clears up until it’s almost nothing. Just rebuilt the turbo with fresh seals and replaced an injector that threw me a code months ago, no change in it at all. Can’t tell if I’m losing coolant as my radiator has a little leak anyway. Smoke doesn’t smell like much out of the ordinary and has a blueish-white color. No tune keeping the egr closed or delete. It’s a 2005 and the only codes I’m throwing are a couple of glowplug codes.
Old Jan 25, 2021 | 02:32 PM
Fefanatic's Avatar
Fefanatic
Partially clogged injector that can't feed full fuel at higher rpms? Worn engine piston rings? Bad valve seals? Blueish would probably be oil, and white/gray most likely unburned fuel. What does a cylinder balance test reveal?
Old Jan 25, 2021 | 02:57 PM
hobohilton's Avatar
hobohilton
Results of a compression test?
Hobo
Old Jan 25, 2021 | 05:00 PM
Bbg's Avatar
Bbg
It isn’t blow-by seemingly. Don’t have the tools to do a balance test but hoping to soon.
Old Jan 25, 2021 | 05:04 PM
Bbg's Avatar
Bbg
Hobo
compression seems to be even and not low based off of cranking over
Old Jan 25, 2021 | 06:59 PM
Bbg's Avatar
Bbg
Okay so I just drove it probably 5 miles, smoke gets more constant the longer I drive it. By the end of the 5 miles it was constant but never too insanely thick.
Old Jan 26, 2021 | 07:00 AM
99powerstrokedF250's Avatar
99powerstrokedF250
This SOUNDS like a classic case of bad injector/injectors. You may not be throwing codes yet but it will at some point throw an injector contribution code. If you have access to a data logger you should be able to pull the info and see which injectors are acting up.
When I had (2) fail simultaneously on my last 6.0, I was told NOT to drive it anymore until the injectors were replaced, as it could damage the engine.
My suggestion is to get it to a good diesel shop and have them diagnose it if you don't have access to the tools yourself.
Bbg
Jan 25, 2021 10:22 PM
JaySVX
Nov 20, 2019 02:29 PM
fords/harleys
Oct 8, 2018 04:58 PM
CG-ITS
Dec 11, 2015 11:16 AM
cleebmx
Aug 15, 2007 03:10 PM
