Air Leak?
Old Jan 23, 2021 | 02:39 PM
Aidanparm38's Avatar
Aidanparm38
Air Leak?
I tried to start up my truck today and it just kept on cranking and wouldn't start. and by the time it was trying to start i was cranking the starter for more than I was wanting to and so let off the starter. I'm starting to think that it might be an air leak and is the reason why its having trouble starting. what could be all the possible areas be for a air leak in my fuel system. thanks in advance.
Old Jan 23, 2021 | 02:45 PM
hobohilton's Avatar
hobohilton
Glow plugs not working as designed.
Hobo
Old Jan 23, 2021 | 02:52 PM
Aidanparm38
it shouldn't be my glow plugs are bad. right? I've tested all the glow plugs with a test light and they all lit up the test light. and my glow plug controller clicks and my wait to start light stays on for a while,
Old Jan 23, 2021 | 03:03 PM
hobohilton's Avatar
hobohilton
Wrong............. Just because the test light "Lights Up" it does not mean the glow plug is heating up. Remove them and bench test each one.
Hobo
Old Jan 23, 2021 | 03:11 PM
Aidanparm38
the thing is, when I was trying to start it, it wasn't blowing white smoke at all in the beginning and only was smoking a tiny bit after a bit of cranking.
Old Jan 23, 2021 | 04:06 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Glow Plugs very seldom short to ground they Burn OPEN so the Test light Method is a Sound test on the individual plugs.
what are the chances that all the plugs short to ground ???
when you test them with the Test Light you note the brightness of the Lamp IF you have one that is quite a bit brighter than the rest then "Maybe" it is shorted to ground.
The Test light is the Approved FORD method of testing.
it's also easy to cycle the plugs then feel the plugs to see if they are warm on a cold engine (you could use a good laser pyrometer/Thermometer in place of finger)
a dead giveaway that the GP's are conducting is watching the Voltmeter drop.
IF you are sure that the Glow System is functioning properly then you may well have a fuel issue.
Old Jan 23, 2021 | 04:22 PM
Aidanparm38
I'm fairly certain it isn't a glow plug issue. I've been having problems not starting easy before but sometimes even when its cold it just fires right up. kind of moody I guess you could say
Old Jan 23, 2021 | 05:31 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
one way to tell is let the truck set for a few days then carefully remove the filter to see if it is Full.. IF it ain't full then you have a leak.
IF it is full then then you may have issues with the IP
Check the Stanadyne DB2 troubleshoot guide for related issues.
also How is the Compression <<=== I know I had to ask
Old Jan 23, 2021 | 07:11 PM
Aidanparm38
the compression exists? idk it just works soooo
Old Jan 23, 2021 | 07:51 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the only other issue is IF your starter is not Cranking the engine at 200 RPM
Flatty
May 16, 2017 09:12 AM
Peterbilt376x
Apr 29, 2009 12:39 PM
me Mickey C
Feb 4, 2008 12:47 PM
Fordzilla_4X4_King
Jul 6, 2003 01:00 PM
Nonres
1997 - 2003 F150
Feb 10, 2003 05:15 PM
