Fan clutch
Old Jan 23, 2021 | 09:46 AM
charter.pa's Avatar
charter.pa
Fan clutch
I am building a Hiboy 4x4. I am putting a 420 torque 390 engine in C6 auto PS and A/C. I had a 2WD F250 camper speicial radiator redone with 4 rows, trans cooler internal. It has the 21" shroud. I have a 19", 7 blade, steel center, aluminum blade Ford fan Part number says it is for a 429. Based on the info I provided what fan clutch would I need for the best cooling and performance
Old Jan 23, 2021 | 09:50 AM
beartracks's Avatar
beartracks
The most effective would be a thermal and rpm style such as for an RV. They will slip at higher rpms
Old Jan 23, 2021 | 10:16 AM
charter.pa's Avatar
charter.pa
Do the amount of or style of the fins play a role in the cooling ? The 429 has a solid close gap row of fins from the center outward. The 390 has wider gaps and is in 3 sections ( rings) spaced 1/2" apart. Thank you for the advise. I looked up thermal clutch. I did not know any of that. It also explained how to correctly check the operation. I didn't know that either.
Old Jan 23, 2021 | 10:28 AM
440 sixpack's Avatar
440 sixpack
Clutches are pretty generic. my Challenger, Ford and Jeep all take the same clutch . as long as it bolts up and clears the radiator it will work. thermal is the best though .
The fit on the pump shaft sometimes requires a bushing and the distance from the fan to the radiator is crucial.
Old Jan 23, 2021 | 11:19 AM
charter.pa's Avatar
charter.pa
Ok wasn't sure. That distance is determine by how deep the fan sits in the shroud ? Half in half out I believe I was told.
Old Jan 25, 2021 | 10:55 AM
SFaulken's Avatar
SFaulken
I pulled a 19" fan and clutch off of a later Bricknose 460 in the boneyard, and clearanced the factory shroud for my '75 with 390, works great, cost me all of about $20 as I recall. Never gets hot, not sitting in traffic, not pulling grades, or pulling trailers.
Old Jan 25, 2021 | 03:34 PM
charter.pa's Avatar
charter.pa
Thank you. I will give this 429 clutch a try. It seems to be ok
bmoody2001
May 20, 2012 07:10 PM
Ritory
Nov 22, 2010 04:02 PM
fling
Jun 2, 2005 09:47 AM
Crowbar65
Apr 29, 2003 02:46 PM
Supercab
May 2, 2002 09:31 PM
