Axle ratio
Old Jan 21, 2021 | 09:12 PM
HuskerFarmer's Avatar
HuskerFarmer
Axle ratio
What axle ratio is best for 35” or 37” tires?
Old Jan 21, 2021 | 09:19 PM
Flyct's Avatar
Flyct
FTE Community Team
what engine?
Old Jan 21, 2021 | 09:21 PM
kehinnc's Avatar
kehinnc
Originally Posted by Flyct
what engine?
What year Truck?
Which transmission, 6 or 10 speed?
What's your current gear ratio?
Old Jan 21, 2021 | 09:29 PM
HuskerFarmer
Ordered F 350 diesel. Went with 3.55 without thinking about putting on bigger tires. I still have time to change my order. Really want to run 37s
Old Jan 21, 2021 | 09:33 PM
ford390gashog's Avatar
ford390gashog
Change to what? The 3.55 is the lowest ratio offered in a SRW 6.7 pickup.
Old Jan 21, 2021 | 09:35 PM
4wd6.7L's Avatar
4wd6.7L
......my bad
kehinnc's Avatar
kehinnc
Is it SRW or DRW?
Look on page 11 of 36 in the attached 2021 order guide.
Old Jan 21, 2021 | 09:49 PM
2five7's Avatar
2five7
Rule of thumb is you lose .1 in gear ratio for each 1" taller tire you go. So you're going from a 34 to a 37, your 3.55 will be 3.25 effective. F250's come with 3.31 stock, so your basically right there. I wouldn't sweat it unless you tow really heavy frequently.
Old Jan 21, 2021 | 09:53 PM
Flyct's Avatar
Flyct
FTE Community Team
Don’t fret the 3.55s. My 2020 F350 CCSB diesel has 3.31 and I tow a 14,000 lb 5th wheel. It does a great job win the 10 speed and 6.7L diesel.
I had a 2017 with 3.55s and a 2019 F350 with 3.31. The 2020 with 3.31s is a rocket ship compared to the previous trucks due to the extra power and 10 speed.
Old Jan 21, 2021 | 10:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
3.55 will be just fine.
Old Jan 22, 2021 | 06:49 AM
HuskerFarmer
Thanks for the input. Appreciate it.
Old Jan 22, 2021 | 12:00 PM
Sf jakey's Avatar
Sf jakey
why the change to 3.31? Does the new 10 speed make the 3.55 unnecessary? I would imagine the 3.31 yields noticeably better mpg at highway speeds of 75+?
Old Jan 22, 2021 | 01:47 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Fuel mileage and emissions. 3.55's will still have the better actual performance...but we are only talking about 0.24 to 1 of a difference here. Nothing drastic.
Old Jan 22, 2021 | 02:56 PM
Flyct's Avatar
Flyct
FTE Community Team
Back in MY 2017 and 2019 in order to get the 3.55 with 18" tires required that you also order Heavy duty front springs(HD option, Snow Plow or Camper option). My 2017 was purchased off the lot. I didn't like the ride f the HD front springs so when I ordered the 2019 the only axle available with standard front springs and 18:" tires was 3.31.
Ford agreed to Lemon Law (buy back) my 2019 due to an intermittent starting problem. . Before the buyback was finalized the dealer proactively ordered a 2020 with the exact same configuration of my 2019. So it was ordered with 3.31s even though in 2020 you could get 3.55.with 18" tires and standard front springs.
Now I will say that the 3.31 with the 2020 diesel is great. The transmission software logic will keep it in 9th gear at 60 mph if it is needed. I'm getting about 23 MPG at 60 MPH unloaded. About 11 MPG with the 14,000 lb 5th wheel in tow. The 2020 6.7 diesel is much more responsive and little turbo lag compared to the previous years.
GoingGreen
Jul 10, 2018 04:19 PM
NotMyHusbandsF150
2009 - 2014 F150
Jul 5, 2011 07:40 PM
petei
6.7L Power Stroke Diesel
Jul 6, 2010 09:06 AM
kooper909
Aug 13, 2008 06:44 PM
