I'm looking to see if someone has a good pic' of the under hood hinge mounting brace. I'm having to rework the hood where the brace is spot welded to the hood and need to know if my positioning on the brace to the hood is correct.
I need the dimensions of that folding bench/rack that's holding up the hood... I need to build one to hold my front flip doghouse to work the inside surface
Here is an ebay link to one Eastwood 500lb Capacity Portable Autobody Work Stand | eBay
I didn't buy mine from Eastwood but they are fairly inexpensive from various vendors. I have a few of them around the shop....
Many times I will place a couple of 2x4s across the stands to make a larger support surface.
This is the hood I posted in https://www.ford-trucks.com/forums/1...painted-6.html, post #85. Paint is House of Kolor Euro Red base coat applied over KD3004 sealer and finished with USC01 clear coat. Finish was sanded to 2000 grit and buffed/polished.
