General information
Old 01-24-2021, 08:01 PM
lonewolf_'s Avatar
lonewolf_
lonewolf_ is offline
Scope Wizard
I've actually seen a couple diesels with the 44TTB.... BUT I cannot say they came that way....
there are Coil Spring kits to replace the leaf springs too... these trucks are OLD and it's anyone's guess what folks do
According to Blue Oval the 44 was used on trucks up to 8500 all diesels I have seen are above that so TJC is probably 100% correct.
https://www.blueovaltrucks.com/tech-...b-front-axles/
  #107
Old 01-24-2021, 08:35 PM
jjqllc's Avatar
jjqllc
jjqllc is offline
You learn something new everyday. Tomorrow I have to go out and see if mine is a 44 HD or 50. It's 8 bolt, but that doesn't tell me anything more. Thanks for the link Lonewolf. Rep added!
  #108
Old 01-24-2021, 08:37 PM
DarkOverCast's Avatar
DarkOverCast
DarkOverCast is offline
The part from blue oval is correct, the 8600lb got the Dana 44HD, it's beefed up from the regular 44. I have one in my 85, in 85 only the f350's came with the 50, and somewhere (maybe 85) it crossed over to where the 350 got the Dana 60 and the 250 got the Dana 50.
The 44hd is basically identical to the 50, other than smaller hubs/bearings and a skimpier passenger side axle shaft.
The 50 axle shaft is a direct swap I believe, as are the whole axle assemblies.
The coils would sure make the ride smoother, but I like leaf sprung axles for work trucks, and it actually rides pretty smooth compared to the Dana 60 axle which rides like a tank..
  #109
Old 01-24-2021, 08:48 PM
DarkOverCast
  #110
Old 01-24-2021, 08:51 PM
jjqllc's Avatar
jjqllc
jjqllc is offline
X2 on the coils. I seen some kits to upgrade to coils, but something like $2500. I'll stay with the leafs a save my money. Waiting on my shackle bushings to be delivered by the way.
  #111
Old 01-24-2021, 08:53 PM
jjqllc's Avatar
jjqllc
jjqllc is offline
Damn--I don't even have to out to look now. I got the 50. Thanks DOC. Reps all around.
  #112
Old 01-24-2021, 09:04 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
my Rep Gun is broken as I tried to give em back but I guess I have to pass more around
  #113
Old 01-25-2021, 04:23 AM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,309 Likes on 2,302 Posts
Originally Posted by Dylan Fileccia
I will do that. I can get those through work. Fun part is I need to replace the locker on the drivers side. The engagement *** is pretty loose and a little sunk and it does not audibly click like the passengers side. I have really never delved into how lockers work so I don't know the first thing about fixing them
just go to a off road shop and grab a set of warn, or milemarker hubs. you will be years ahead of the game, and cheaper price too.
  #114
Old 01-25-2021, 04:26 AM
tjc transport
i ain't rite
Originally Posted by DarkOverCast
^^^this^^^
pre 85 F-350 had D-50 ifs.
D-60 solid for the F-350 did not start until 86 model year.
  #115
Old 01-25-2021, 04:35 AM
Dylan Fileccia's Avatar
Dylan Fileccia
Dylan Fileccia is offline
Originally Posted by tjc transport
^^^this^^^
I have the red lockers
  #116
Old 01-25-2021, 04:38 AM
tjc transport
i ain't rite
color of the **** does not matter, it is the size of the locker. if it is flush with the hub, it is a D50. the D44 locker is slightly smaller than the hub.
  #117
Old 01-25-2021, 05:05 AM
Dylan Fileccia
  #118
Old 01-25-2021, 05:08 AM
Dylan Fileccia
Here is the tach at high idle btw once it drops high idle it will read 0 and I do have my parking brake set btw
  #119
Old 01-25-2021, 01:17 PM
DarkOverCast
You have the Dana 50, also on the tac, you can try removing it and cleaning it and making sure where the wires leave the sensor they're not frayed and touching. If they are you can put some silicone or hot glue around them to insulate them from eachother.
It's real common for the tac sensors to read like that when they get old and tired.
  #120
Old 01-25-2021, 01:46 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the Tach issue was all discussed in the first few Posts in this Thread..... go back and Re-Read
What I'm trying to tell you is that with E4OD transmission Tach signal is IMPORTANT... IF it is degraded then it WILL lead to Early Transmission Failure.
Quick Reply: General information
