severe pinging problem
Old Nov 11, 2003 | 11:14 PM
proeliator's Avatar
proeliator
Well, apparently it IS too much advance or you are running swill for gas. I have known some guys to switch stations and it was all they needed for the problem to go away.
Old Nov 11, 2003 | 11:25 PM
Crumm's Avatar
Crumm
I will try putting different gas in it. I am on the first tank I have ever run through it. When I got it there was about 1/8 of a tank in it and I suppose it was about 10 years old. I didn't drain the old stuff I just filled it up with new. Most definitely could be the problem. I suppose I should run it low then drain the rest to get all new gas in it instead of a blend of new and major old gas.
Old Nov 12, 2003 | 02:05 AM
Ratsmoker's Avatar
Ratsmoker
With 9:1 compression or less there should be nobody having problems with 87 octane and 44 degrees total timing. Best results for total timing in an FE will usually occour between 38 and 44 degrees.
Old Nov 12, 2003 | 04:33 PM
hbtwarrior's Avatar
hbtwarrior
you know on the edelbrock carbs the 2 adjusting screws are for adjusting ar flow, not fuel flow, and its good to start off by adjusting them from about 3 to 4 turns out and work from there. im working with the same thing right now, but your timing also has to be pretty good to.
Old Nov 12, 2003 | 05:01 PM
proeliator's Avatar
proeliator
In theory, you are entirely correct. However, I've known some independent stations whose regular was so poor that running their gas would cause pre-detonation where there had never been a problem before. The quality of gas these days makes me ill. I run aviation gas in the '73 run I mud drag for that reason.
Old Nov 13, 2003 | 02:00 AM
BobbyFord's Avatar
BobbyFord
There is no horsepower increase on a dyno for these street engines beyond 36 degrees total timing advance.
___________________
Bobby
Old Nov 13, 2003 | 02:11 AM
Ratsmoker's Avatar
Ratsmoker
I disagree instig8r63. Many people who have dynoed their FE engines have shown best results over 40. Most people get best E.T.s with about 42 degrees. Of course optimal timing has many controlling factors but the biggest one is combustion chamber design. That is where 40 year old technology is lacking.
And I agree Seth. Sometimes the gas quality is pretty low. It makes you wonder how they pass inspections.
Old Nov 13, 2003 | 09:29 AM
Crumm's Avatar
Crumm
Well I passed an I/M test yesterday and everything was well within spec. But it is still pinging under hard acceleration. I have three fuel tanks but only one had fuel in it so this morning I filled one of the other ones with 90 octane and took it for a drive. It sounds just like it does with the 87 octane. I am still at 10 degrees should I try less?
Old Nov 13, 2003 | 10:21 AM
Ratsmoker's Avatar
Ratsmoker
Have you tried any carb cleaner? Run a whole can through the carb. 1/2 of it in the right primary and the other in the left while you keep the engine running. Wait until it is at full operating temp before you do this. This will eliminate the carbon buildup possibility.
Old Nov 13, 2003 | 10:38 AM
Crumm's Avatar
Crumm
I ran a 1/4 of a can through it. I will run the rest through it today. You say the right and left primary. No need to do the secondaries ?
Before I bought the truck it basically sat for the last 10-15 years only being started every few months and taken for about a 3 mile drive. When I first got it I didn't notice the pinging like I do now after having it for a few days. I may have just not been tromping the throttle but I didn't notice it for a day or two. The distributor was loose so the timing was way off (about 20 at idle) and the pinging seemed to show up after I properly timed it. With the timing advanced way to far like it was I had trouble getting it started when the engine was warm. Wouldn't this advance make it ping worse? It didn't seem to.
Old Nov 13, 2003 | 10:10 PM
hbtwarrior's Avatar
hbtwarrior
im not positive but isn't it a possibility that if the truck sat up that long that the lifters could be worn out, causing it to ping when the timing is wrong, and also try some fuel additive, something to add in the tank that cleans the system out, and i always run a hotter coil than a stock coil on my fords burn the fuel better than a stock ignition coil
Old Nov 25, 2003 | 12:05 AM
Crumm's Avatar
Crumm
Well I ran a whole can of carb cleaner through the carb. I also added a can of Sea Foam motor treatment to the fuel. I then put a half a can of Sea Foam in the crankcase and dumped the other half of that one down the carb. The "parts guy" told me that was the best stuff they had. It is suppose to remove all carbon, gums and varnish. I am now confident that the system is clean.
I have also tried the best gas I can get in town. I tried 87, 90 and 92.
After all this it still pings under acceleration. It seems to be a little better with the high octane fuel but not better enough to justify $.20 a gallon.
I have the timing at 10* and it gets a maximum of 35* so I don't think that is the problem. I am thinking that it is running to lean. I have a Holley 4160. How do I adjust it to get a little richer? I see one screw on the side that has a little cover over it with arrows telling which way is rich and which is lean but don't know if this is the idle setting or what.
Old Nov 25, 2003 | 12:24 AM
  #28
baddad457's Avatar
baddad457
I'm with ratsmoker on this one, y'all running low comp ratios shouldn't be having pinging problems. The 10.5 to 1 390 in my 68 Merc runs all day long on 87 octane, NEVER pings. Cam is a Crane 272 degree Energizer, timing is set at 12 degrees initial, dist is the original for the car with a pertronix unit. Intake is a 428PI, carb is a 3310 Holley, with the lighest sec spring, and a 50cc accelerator pump. Ran a modified 600 cfm Holley on it awhile and it did fine too. It did ping before I overhauled it and it had the stock cam in it and 2 bbl carb.
Old Nov 25, 2003 | 12:53 AM
  #29
Crumm's Avatar
Crumm
I shouldn't but do have pinging. How do I richen up my Holley 4160?
Old Nov 25, 2003 | 01:06 AM
  #30
baddad457's Avatar
baddad457
To richen it, you need to change the jets. To richen the idle mixture, just turn the small screws on either side of the primary metering block counterclockwise. The jets are located in the primary metering block inside the fuel bowl. If you have a single feed carb, then you may need to have extra "O" rings on hand to replace the ones on the fuel transfer tube if you tear them, upon reassembly.A good method to insure they don't tear is to dip them in brake fluid just before reassembly. You will also need some jets that are 2 to 4 sizes bigger than you now have, try going up 2 sizes then up 2 more . You may also need new metering block and bowl gaskets.
