Sponsored by: Real Truck
2006 Electrical Problems
Old Jan 18, 2021 | 11:38 PM
John Chevalier's Avatar
John Chevalier
Guys I have searched and have not been able to find a solution. When cold outside I can not shift the truck from park, no power or illumination or function on the automatic temp control, the automatic door locks do not lock above 15 mph, and tapping the brake pedal will not disengage the cruise unless you really push on the pedal which overrides the brake pedal switch and uses the pressure switch on the master cylinder as a backup. If I leave a portable heater in the truck and keep the interior warm( which is not a good idea) or it is warm outside which keeps the interior warm then everything works as it should. Any help or direction will be much appreciated as driving every morning with no heat in 30 degree temps is getting old lol. Thanks in advance for any tips or guidance.
exiled
Jan 21, 2023 09:09 AM
RAMBOv10
Dec 16, 2019 11:22 AM
ithaca1230
Jul 7, 2016 01:54 PM
slenser
May 11, 2011 08:16 PM
fast freddie
Aug 11, 2004 06:41 PM
