Heater issue ?
Old Jan 18, 2021 | 05:13 PM
Steelhant's Avatar
Steelhant
Heater issue ?
2020 f-250 Lariat 6.7....defrost works, warm air comes out of air condition vents...but no floor air any idea..figures now getting cold and I guess some type of door that directs the air not working..
Thanks,
Chuck
Old Jan 18, 2021 | 05:20 PM
C12H24's Avatar
C12H24
Even if you manually control the HVAC you can't get air from the floor? If you manually select floor air, from what vents does the air flow? Make sure you are feeling all around for air on the floor. It might not be where you think it should be. You could be looking at a blend door issue. Do a search here to see if there is an HVAC reset/calibration procedure. Manufacturers usually have these, like "Hold the power button while pressing the fan up" or something like that to put it into a service mode.
Old Jan 18, 2021 | 05:24 PM
Steelhant's Avatar
Steelhant
Not sure how I can manually get the floor air on, I just have buttons, thanks for the reply !
Old Jan 18, 2021 | 07:14 PM
BC2019F250's Avatar
BC2019F250
You should be able to choose the floor vent by choosing the correct button. The Sync HVAC screen should also show the buttons.
Old Jan 18, 2021 | 07:39 PM
Steelhant's Avatar
Steelhant
Don't know what I did but I followed what both of you told me...hit some buttons in the Sync screen and I have HEAT...Thank You...Thank You..
Crazy how this stuff works, saved me a trip to the dealer !
Just curious why it happened.
Thanks Again,
Chuck
Chris Ko
Jun 23, 2017 06:32 AM
youngfordkid
Jan 29, 2012 03:00 PM
brd7666
General Automotive Discussion
Mar 16, 2011 05:04 PM
jowilker
16
Jan 7, 2009 08:15 AM
roree
Aerostar
Dec 23, 2008 04:04 PM
