1956 Ford F100 steering box
The following users liked this post:
Parts are available. Some welding is needed when rebuilding the box.
https://midfifty.com/item.php?INV_ID...ller-gear-1956
ask Harrier about his box rebuild. He got parts but not all he needed. Joe you out there?
Maybe you can get the parts here: https://www.lmctruck.com/1948-56-for...umn-components
I bought the complete replacement from midfifty: https://midfifty.com/item.php?INV_ID...will-fit-53-55
Maybe, you should simply wait until they have them in stock again.
If you can find a 1956 F-600 steering box, they are virtually plug and play. You have to drill a new hole in the frame and that's it. Much stouter internals. slightly slower ratio and easier steering effort. They last a long time in the much lighter F-100. The reason the original F-100 box wears out so quickly is that they are under designed for the work they do. Keeping gear lube in them is key no matter what. Don't use grease.
