1956 Ford F100 steering box
Hello, I did an introduction, new to this site. I'll jump right in, I have a 1956 Ford F100 steering box/column that needs a rebuild. Are there parts available, or replacement ideas> Thanks everyone!
1 Attachment(s)
Parts are available. Some welding is needed when rebuilding the box.
https://midfifty.com/item.php?INV_ID...ller-gear-1956 |
There are also guys out there who service the boxes if you have more money than time/ambition.
I know of one out in CA whom I have sold cores to several times in the past. JML |
Thank you for the replies! I've contacted Mid-Fifties, 56 steering parts are out of stock and they don't know when they will get parts in stock. I'll keep looking, Thanks!
Originally Posted by Olyeller26
(Post 19685064)
Well, I received a response back from a company in California, has anyone purchased/dealt with a company by the name of Jamco Parts? They claim to have the rebuild kits in stock.
Thank you everyone for your responses! |
Maybe you can get the parts here: https://www.lmctruck.com/1948-56-for...umn-components
I bought the complete replacement from midfifty: https://midfifty.com/item.php?INV_ID...will-fit-53-55 Maybe, you should simply wait until they have them in stock again. |
Originally Posted by rico56
(Post 19688221)
If you can find a 1956 F-600 steering box, they are virtually plug and play. You have to drill a new hole in the frame and that's it. Much stouter internals. slightly slower ratio and easier steering effort. They last a long time in the much lighter F-100. The reason the original F-100 box wears out so quickly is that they are under designed for the work they do. Keeping gear lube in them is key no matter what. Don't use grease.
Originally Posted by Steve
(Post 19688682)
Originally Posted by abe
(Post 19688773)
F350 and F500 are the same as F600 and will fit as you described above.
(Post 19688773)
F350 and F500 are the same as F600 and will fit as you described above. So this will help your search. However, you are limited to 56 trucks, not 53-55. The column in 56 trucks is shorter due to the redesigned steering wheel.
Have you checked Rockauto.com?
Good News, finally found parts to rebuild the box, Thanks for everyones help!
Don’t tease, who had the parts?
