Does the computer need to be reset when installing new batteries?
Old Jan 17, 2021 | 05:08 PM
Fandini's Avatar
Fandini
Does the computer need resetting when replacing old batteries with new batteries? I’m seeing info now that says some vehicles need to have the computer reset and it needs to know the batteries are new because new batteries have different charging parameters than older batteries. Also, if switching from a flooded to AGM the computer needs to know because AGM’s have different charging requirements. Is this the case on a 2018 F-350 diesel?
Thanks
Bill
Old Jan 18, 2021 | 05:00 AM
Mark Phillips's Avatar
Mark Phillips
Thanks
Bill
interesting. deep cell batteries have different charging requirements
https://www.interstatebatteries.com/...s-the-big-deal
Old Jan 18, 2021 | 09:20 AM
69cj's Avatar
69cj
I replace one battery at a time. Radio doesn't even lose presets that way.
Old Jan 18, 2021 | 09:22 AM
Fandini's Avatar
Fandini
You know how chargers have different settings for flooded, gel and AGM.
Old Jan 18, 2021 | 09:26 AM
Fandini's Avatar
Fandini
Exactly what I did. However, the mechanic in the video was saying that “SOME” vehicles/brands needed to have the computer reset to know there were fresh batteries in the vehicle. He didn’t elaborate on which brands did or did not.
Old Jan 18, 2021 | 09:27 AM
Tedster9's Avatar
Tedster9
What does your 2018 Truck Operator's Manual say?
Even if there aren't any stupid show stoppers, there will likely be a certain procedure to follow after replacement.
Old Jan 18, 2021 | 09:46 AM
Fandini's Avatar
Fandini
That just makes too much sense! Dang! Feel like an idiot now. I’ll have to take a look at the manual. Brilliant!
Old Jan 18, 2021 | 10:31 AM
Tedster9's Avatar
Tedster9
"RTFM" isn't always a bad idea.
There's sometimes some kind of jiggery-pokery involved - setting the park brake, running the A/C for a few minutes, moving gear selector through every detent. Whatever it is, if the manual mentions something like this, be sure to follow it, it is important.
If otoh it says "See Your Dealer", that's probably a Bad Sign.
Old Jan 18, 2021 | 11:42 AM
System's Avatar
System
Prolocutor
There is no computer reset needed when changing batteries on our trucks. As far as charging profile, there is an AGM setting that shows up in Forscan as an option. I don't know if it works as no one I know has tried it yet. I'm running Odyssey AGMs now on the factory setting and am curious about the change but not enough to have me experiment with it... yet...
Old Jan 18, 2021 | 12:22 PM
kper05's Avatar
kper05
For the 2018 SD the Battery Management System (BMS) is "if equipped." I don't know if that is only single battery gasoline models or if it includes the 6.7L. Page 355 discusses eight hours of sleep (doors locked, don't touch) after battery replacement. It would be helpful if Ford explained how to determine if owners have a BMS vehicle or not.
Old Jan 18, 2021 | 12:32 PM
Just Chilling's Avatar
Just Chilling
Wonder how they do that. Thousands of trucks never sit 8 hours not touched including mine.
Old Jan 18, 2021 | 07:15 PM
kper05's Avatar
kper05
Just have to get home at 8 PM and not leave until about 4:30 AM I guess! My 2017 Fusion has the BMS. The manual discusses taking it to the dealer or use the eight hours option. I'll just fix it with FORscan when I have to replace the battery.
Except for 24/7 fleet.
Old Jan 19, 2021 | 10:11 AM
speakerfritz's Avatar
speakerfritz
does ford sell AGM batteries?
Old Jan 19, 2021 | 11:12 AM
The Bone's Avatar
The Bone
This is how drug dealers figured out the trap door.
Old Jan 19, 2021 | 02:07 PM
Fandini's Avatar
Fandini
Yes. They had some at the dealer but the sizes were a little different than the ones that came in the truck.
