89 150 lock+ignition
Old Nov 8, 2000 | 01:53 PM
juandosperros's Avatar
juandosperros
I have an f150 xlt lariat with tilt wheel. I have replaced ignition switch and gotten lock cylinder working smoothly but cannot seem to get the rod and lever connecting the two in the proper place. Picture in ford shop manual is useless. Do I need to remove the band containing the shift lever to do this?? Any suggestions or reference to a picture would be appreciated.
Old Nov 8, 2000 | 06:26 PM
deleontow's Avatar
deleontow
Sometimes when you remove the switch the gear may come out, if the lock ring is removed or broken, the easy solution to fixing this is, remove the switch and pull the brass gear back out, now using a screwdriver turn the rack till you get to the ignition part, lights on dash should come on, now reinstall the brass gear to fit the small cover and reinstall the lock ring, now when you install the switch, it is on ignition, it should line up, this is providing you did not remove the electrical ignition switch, if so, you need to install it back the the original possision, by looking at the old bolt marks.
If you need further email or call me if you like, you can get my number by going to our web page listed below.
Dave
http://a2ztowing.homestead.com/a2ztowing.html
Old Nov 9, 2000 | 09:36 AM
bgodkin's Avatar
bgodkin
Aus56
22
Oct 22, 2022 12:09 AM
Aus56
Nov 23, 2018 10:44 PM
TexasGuy001
19
Jul 28, 2011 10:25 AM
t28ron
1997 - 2003 F150
Feb 4, 2011 10:58 PM
flyhound
Jan 2, 2005 12:53 PM
