Painting body cladding
Old Jan 16, 2021 | 06:46 PM
Wmnido's Avatar
Wmnido
Want to change the color of the body cladding on my 04 Excursion. Has anyone successfully painted them on the vehicle ? Thank you.
Old Jan 17, 2021 | 05:25 PM
Lance Helmert's Avatar
Lance Helmert
I haven't done it. If the paint is in good shape, you need to clean the cladding very thoroughly. Then sand with 400 grit,clean, use degreaser and wax remover, then paint with base coat of your choice. As many coats as needed, probably 3-5, then apply 2-3 coats of clear within the window of adhesion of the base coat. Once your past that window, you have to scuff the base coat so the clear will stick. Ask the paint supplier for the technical data sheets, they have the information you need. Some places can put catalyzed auto paint into spray cans. You need to take them home and paint immediately, before it cures in the can. The time you have available is referred to as pot life.
Old Jan 17, 2021 | 07:59 PM
Wmnido's Avatar
Wmnido
Thank you ! Sounds great !
Old Jan 17, 2021 | 08:15 PM
Beechkid's Avatar
Beechkid
FYI- you will need a high build primer that is specific for plastics to achieve bonding....most auto paint suppliers have this is spray can form as well...typically about $25 each.
Old Jan 18, 2021 | 08:15 PM
Wmnido's Avatar
Wmnido
Thank you ! I appreciate the feedback.
brcrk
Jun 12, 2012 10:03 AM
bbsitum
1997 - 2003 F150
May 13, 2011 04:23 PM
keith56_cruz_cab
Aug 25, 2009 12:50 AM
BradyCouchman
Paint & Bodywork
Feb 27, 2008 02:24 PM
escape2k3
Escape & Escape Hybrid
Mar 18, 2003 08:31 AM
