The fluid level check will be on the right side of the transmission down underneath by the pan--if it is anything like the 6r80. Check when cold because its right next to the cat. It should hold vacuum so you will hear a noise when you remove the stick.
Here is a part diagram I could find for my truck. Not sure if 2019 transmission would have a opening for the oil level/filler tube.
Oil Level Indicator Part#: 7A020Usages: 07/11/2016 - 07/09/2018, F-Series Super Duty, 6 Speed Auto Trans (6R100) Most parts available next business day.Your Price: $23.15
Oil Filler Tube Part#: 7A228Usages: 07/11/2016 - 07/09/2018, F-Series Super Duty, 6 Speed Auto Trans (6R100) Most parts available next business day.Your Price: $45.25
My 2018 F250 6.2 STX has one. It has the 6 speed transmission not sure if that makes it a 6R100. Did you try looking for the 2018 parts?
Yeah, not having much luck. There has to be someone that has figured this out. There is a couple aftermarket kits for the F150 6R80 Trans, I'm not sure, but may be the same case as the 6R100.
I know that, PITA though if you change fluid, checking and filling not easy.
Never heard of climbing under a vehicle to check the trans fluid and then be required to check cold.
The newer closed systems are just service and refill via pump.
I know the 10spd is easy to get to and you simply treat it like a differential, fill til it runs out.
i cant tell what that sticker says. is it the temp at which the oil should be flush with the fill hole?
I have asked before if any one knows of a dipstick that will retro fit. So far nothing.
I installed the B&M 22200 on my 2019 F250, 6.2, 6R100. Was told more than once that "this part will not fit your 2019 F250." Never an explanation why not? I know the 6R80 and 6R100 use the same case, so I took a chance and spent the $210, worked out the way I thought it would. Now I have a Dipstick, did my first drain and refill and new filter @31,600 mi. Was able to fill though the B&M dipstick. Also installed a Pan with a Drain Plug to make future "Drain and Refills" easier.
