1978 - 1996 Big Bronco
Exhaust Into The Cab. . . .HELP
Old Oct 25, 2003 | 06:40 PM
RyanGruhn's Avatar
RyanGruhn
Exclamation Exhaust Into The Cab. . . .HELP
Hey All,
So it just started getting cold here in PA and I had the windows up today while I was driving. As I accelerated some faint smoke looking fumes came into the cab. After closer inspection I found that it was exhaust coming in through the steering column. Right in-between the steering wheel and the plastic cover that covers wires. I looked under the cab and saw that I had a crack in the manifold, but that is entirely too expensive to fix right now. So my question is, what do you suggest I do in the mean time? Where exactly do you think it’s coming in from and how could I fix it?
Ryan
Old Oct 25, 2003 | 07:52 PM
joebronco94's Avatar
joebronco94
sounds like you have a hole in the fire wall. Check all plugs if thay are missing or cracked. any holes should be filled with rubber and silicone. that should fix it
Old Nov 22, 2003 | 01:34 PM
RyanGruhn's Avatar
RyanGruhn
Hey All,
So I think I found the leak: Inside the engine compartment there is a rubber boot that covers the steering rod close to the firewall. My boot is completly ripped; could it be comming in from here?
Ryan
tripletap3
Feb 3, 2016 07:19 PM
nothercrash
Nov 21, 2010 06:52 PM
mvoeller2
Aug 3, 2008 10:25 AM
jocacliff
2004 - 2008 F150
Jul 12, 2005 08:09 AM
