Rear End Noise
Old Jan 15, 2021 | 02:06 PM
williamlreidlll's Avatar
williamlreidlll
Rear End Noise
I am hearing a noise in the rear when I quickly excelerate. It only lasts for a second then stops. I notice this, there is no fluid on the ground.
Old Jan 15, 2021 | 02:23 PM
Dweber85rc's Avatar
Dweber85rc
It looks like your pinion seal is leaking. Check the fluid level and/or change fluid and open it up to check for shavings.
Old Jan 15, 2021 | 03:22 PM
muhford's Avatar
muhford
Replace that diff cover ASAP. Looks like it is probably paper thin and has been leaking for awhile.
Old Jan 18, 2021 | 08:41 AM
Forresth's Avatar
Forresth
not much oil in those to leak out. the lack of a puddle just means it didn't loose it all in one place.
Old Jan 18, 2021 | 10:43 AM
thor363's Avatar
thor363
Mine had a low shudder and a small vibration at certain speed. Turned out the pinion seal and small amount of diff lube was only a symptom of the issue. I needed to have new pinion bearings, crush collar, and seal installed in mine. All told locally it was about $350 to have that done, which was cheaper than my time to do it. That was obviously not at the dealer. The rhythmic sound I was hearing at speed got worse on a trip back from Canada, and I had it addressed asap when I returned. Don't just address the symptom since just doing a seal requires that pinion flange to be removed anyway. Oh yeah, I recall it was a worse sound when accelerating from a stop, and it was quieter at speed though there was noticeable vibration at speed.
Jonathan W. Bentley
1997 - 2003 F150
Apr 23, 2017 09:28 PM
macster60
Jun 20, 2014 07:16 PM
aspellicy
2004 - 2008 F150
Jan 29, 2009 08:10 PM
Kikir
Apr 18, 2008 12:58 PM
rugermack
Dec 11, 2007 07:47 AM
