Second fuel gauge?
Old Jan 15, 2021 | 12:55 AM
Flyinbolts's Avatar
Flyinbolts
Second fuel gauge?
I have the two tank f150 xlt from 95
I'd like to replace the stock gauge and add a second one so i can see both tanks status. Anyone done this? Any problems with it? I'd just change the switch to be a tank toggle.
Any gauge you recommend that reads true to stock sender?
Thanks!
Old Jan 15, 2021 | 02:14 AM
88n94's Avatar
88n94
I'm curious as to why you think you need this? If everything is working properly you can read the tank you are running on and always switch temporarily and check or recheck the other tank.
Old Jan 15, 2021 | 07:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Completely agree. There is absolutely zero reason to have a second fuel gauge.
Old Jan 15, 2021 | 08:40 AM
Flyinbolts's Avatar
Flyinbolts
There's 2 tanks.
I asked the question. Looking for an answer not bs questions asking why.
Old Jan 15, 2021 | 09:28 AM
My4Fordtrucks
Originally Posted by Flyinbolts
There's 2 tanks.
I understood that. My truck also has two tanks. I didn’t give you bs questions asking why. If you don’t remember how much fuel is in the other tank you can momentarily select the other tank and it will register how much fuel is in the other tank then move the switch back to the tank you were using. It will indicate either fuel tank as long as there is power.
Look for a gauge that reads the same resistance scale as the sending unit. Get a wiring diagram to figure out how to wire it up. Good luck with your project.
Old Jan 15, 2021 | 09:43 AM
Flyinbolts's Avatar
Flyinbolts
I really don't care about your opinion. That's the great part. I asked if anyone had done it and if they had gauges they knew worked. Not for a lesson on flipping the switch that a you might or might not know breaks, shorts, etc if you look at it wrong.
I also don't need a wiring diagram. I just need the two pieces of info I asked about.
So do you have an aftermarket fuel gauge you'd suggest that you know functions?
Old Jan 15, 2021 | 10:04 AM
ford390gashog's Avatar
ford390gashog
Don't think you're going to get anyone to help you. If flipping the switch is too hard you will be on your own for two fuel gauges.
Old Jan 15, 2021 | 10:09 AM
Flyinbolts's Avatar
Flyinbolts
It's really sad and funny.
I asked a simple question and all yall can do is ask why and hurl insults.
Next.
Old Jan 15, 2021 | 10:10 AM
SFaulken's Avatar
SFaulken
With his winning attitude, I certainly second that. You're wanting to do something that most people see no good reason to do, so they're not going to have the information sitting around. If this is what you want to do, you're going to have to do some research.
Old Jan 15, 2021 | 10:19 AM
Flyinbolts's Avatar
Flyinbolts
I don't see any answer here in your winning response, but thanks for letting me know that you don't do this and thus nobody in the world ever would do it.
My question remains unanswered.
Thanks y'all
Old Jan 15, 2021 | 10:26 AM
My4Fordtrucks
Next.
No one hurled any insults. “We” do not understand why you would need/ want to make this modification.
The switch does not break, short etc if you look at it wrong. I believe the one in my truck to be the original one from 1989.
You will most definitely need a wiring diagram to make this modification to the circuit.
The gauge needs to match the resistance of what is in this schematic.
Courtesy of subford
A couple minute search found that info. I guess you couldn’t be bothered to look and instead wanted it spoon fed to you. Bye.
Old Jan 15, 2021 | 10:52 AM
Guitarjohnny's Avatar
Guitarjohnny
Attitude or what! Don't think that's going to get you much help around here.
Old Jan 15, 2021 | 12:19 PM
rla2005's Avatar
rla2005
I agree it was a simple question that deserved a simple answer. I have never run across anyone who has added a second fuel gauge or gauge that display both tanks. Those type of gauges are used in aircraft and can be pricey. A little research shows the ones I found will not easily work for your quest. You could install a second fuel level gauge to display the other tank. Or as you stated delete the factory gauge and perhaps install two gauges.Bypass the fuel sender contacts of the tank selector switch then wire to the respective gauge. Just be sure to use a fuel level gauge that is compatible with the factory sender resistance ratings. Empty = 22.5 ohms, Full = 145 ohms.
For whatever reasoning you want to do this is not my place to judge. Some people install running boards on their trucks too. I personally hate doing that but do not actively criticize those who do. To each their own.
Old Jan 15, 2021 | 02:05 PM
85e150's Avatar
85e150
Old Jan 15, 2021 | 06:51 PM
Fomoko1's Avatar
Fomoko1
Sorry to have to lock this thread folks, it's run off the rails.
jimbo beam
Dec 29, 2014 09:33 AM
imjwm
Jun 3, 2014 02:43 PM
Revmitchell
Jan 30, 2011 01:03 PM
wscheue
Jul 2, 2001 06:20 PM
