GP issue 1987 6.9L
Old Jan 12, 2021 | 03:51 PM
KYLEE6.9L's Avatar
KYLEE6.9L
GP issue 1987 6.9L
I’ve got an 87 F250 with the 6.9L idi and I have tried just about everything I can think of to get the glow plugs to work including replacing all the glow plugs as well as the gp relay under the air filter and changing the pushbutton switch. If I spray starting fluid it starts up just fine and as long as the coolant temperature stays relatively warm I can shut it off and on throughout the day. Help!!
Old Jan 12, 2021 | 04:16 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Manual GP wiring.....
Old Jan 12, 2021 | 04:24 PM
SmokeyCapone's Avatar
SmokeyCapone
How's the voltage across the plugs and at the relay? Could be a battery or other electrical issue if not enough power is making its way to the plugs.
When you try to cold start, does the indicator light come on for the GPs, or does it stay dark?
Old Jan 12, 2021 | 05:24 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
he has indicated he has Manual Glow plug modification ....so it really does not matter if the light works or not depending on how it is wired....
but for sure it could be a wiring error ... and yes he should check voltage at plugs and on the Relay and also determine if the relay is even energizing when he pushes the button.
Old Jan 12, 2021 | 11:20 PM
DarkOverCast's Avatar
DarkOverCast
Have you tried bypassing the push button?
Those things are made so poorly now, lonewolf has also mentioned on this forum before about adding a diode on the output side to reduce solenoid kickback. Pretty great idea to make it last imo
Old Jan 12, 2021 | 11:25 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
what the Diode really does is save the contacts on that Cheap push button switch
Trust what DOC says too
Old Jan 12, 2021 | 11:27 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
DOC I keep trying to give you Reps but the forum says I still need to pass it around.....
Old Jan 13, 2021 | 12:45 AM
DarkOverCast
Hey, it's alright, I never cared to have any kind or reputation, take everything I say at face value, either it's good advice or it's not
Old Jan 13, 2021 | 01:05 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
well, I give REPs where deserved and I feel you should have more as you do help here a lot and what you give is good info... mine came from just helping folks as you do
I don't care about them either never asked for them and don't know WTF I got them... but I try pass them around.... I know I have helped lots of folks here but it ain't about me....it's about all of us in this group .... I sure don't have all the answers.... it's the collective that has the answers....
my advise is same take it or leave it ... I don't much care
WE can blame it on TJC
Old Jan 13, 2021 | 01:10 AM
DarkOverCast
Couldn't have said it better myself
Although last I heard TJC was locked up in the Marlboro mental hospital so I cut him some slack
Old Jan 13, 2021 | 01:14 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
I just escaped from Cherry Hill
Old Jan 13, 2021 | 08:26 AM
tjc transport's Avatar
tjc transport
i ain't rite
i AM NOT "locked up" i can escape whenever i want to. the guards are all young pups, and have no idea there are all those underground tunnels and hidden doors around this place.
Old Jan 13, 2021 | 12:14 PM
DarkOverCast
This right here is funny
Old Jan 17, 2021 | 09:19 PM
Nogmshere's Avatar
Nogmshere
Check and make sure you have power going to the GP relay via the 2 10 guage wires in the harness at the passenger inner fender. They become corroded and sometimes won't make contact or when they do because of the high resistance will get very hot and melt. It's a common issue and was the problem I had with mine, even wired manually the solenoid would click but because of the bad connection the GP's wouldn't burn.
https://www.oilburners.net/threads/g...nnector.73856/
mcphm519
Jan 9, 2011 08:54 PM
badasblue
Feb 11, 2010 11:36 PM
ghunt
May 25, 2009 12:31 AM
Kliphton
Apr 24, 2004 04:17 PM
fordtruckluver
Apr 12, 2002 12:33 AM
