V6 to V8 conversion
Old Oct 25, 2003 | 03:18 PM
coolride's Avatar
coolride
V6 to V8 conversion
Does anyone know what and how much work it is to convert from a V6(2.9) 5 speed to a 5.0 5 speed. Appreciate any kind of help, Thanks. Sorry I forgot to mention it is a 1987 Ext. cab. Thanks again
Old Oct 25, 2003 | 04:19 PM
Mike W's Avatar
Mike W
I would consider it to be a major task although it has been done by others.
Old Oct 25, 2003 | 04:45 PM
ford9658's Avatar
ford9658
Swapping a 302 or a 351w into a ranger is not really any harder than changing engines in any other car. I helped a friend of mine put a 302 in his Bronco II. If you want a 5 speed you can use the current ranger tranny but you will have to order a special bell housing, if I were you I would go with the T-5 tranny out of a mustang it is a little tougher when it comes to extra torque. Also you will have to get a oil filter relocation kit because on the 302 the oil filter is locates right in the steering sector of the ranger. you can design an exhaust system to your liking. a regular clutch fan will not fit so you will need an electric fan but those are easy to come by a 17 inch fan will work. The other thing is if you are going to install a carb v8 or a efi v8, since your ranger is efi I would get the fuel injected v8 because your current fuel system will work with it, unless you build your v8 to produce more than 250 horepower. Any way have fun with your project
Old Oct 27, 2003 | 04:52 AM
coolride's Avatar
coolride
Thanks guys. Do you or anyone know where or if I can make some of these adapters or would I have to buy them. Thanks in advance.
Old Oct 27, 2003 | 05:50 AM
Rockledge's Avatar
Rockledge
https://www.ford-trucks.com/V8Conversions.html
https://www.ford-trucks.com/AAInstructions.html
Old Oct 27, 2003 | 10:36 AM
coolride's Avatar
coolride
Do they also have some help, Q & A there as well. Thanks
Old Oct 27, 2003 | 06:20 PM
jamesbell's Avatar
jamesbell
Check out northernautoparts.com part #1817 and #1818 cool stuff and work well.
Old Oct 27, 2003 | 08:37 PM
coolride's Avatar
coolride
Thanks James I'll look into that. I see you have a 66 Stang as well, that's great I've just started restoration on a 65 Fastback. Thanks to everyone and keep the replies coming if you think they will help.
JP_McCann
Sep 13, 2007 08:11 AM
Chris65
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 2, 2005 11:26 AM
davedawe
Feb 2, 2005 06:25 AM
