Door tag rivets
Old Jan 10, 2021 | 07:35 AM
john jamieson's Avatar
john jamieson
Door tag rivets
At some point I will be replacing the drivers door on my truck. In looking at the proper rivets, How are they installed?
Old Jan 10, 2021 | 09:12 AM
vze2c2gb's Avatar
vze2c2gb
Slight hand pressure with a punch is all it takes.
Old Jan 10, 2021 | 09:33 AM
James_Western_Canada's Avatar
Marti has the rivets, $1.50 ea, one would hope there are instructions??
https://www.martiauto.com/itemselect...lecteditem=yes
Old Jan 10, 2021 | 11:07 AM
skidoorulz's Avatar
skidoorulz
Just make the blister a dimple by pushing in
Old Jan 10, 2021 | 03:16 PM
gangstakr's Avatar
gangstakr
What happens if the proper rivets are not used? Who can tell what the real rivets are compare to a rivet in your box? I have the proper size plus the ones from "Marti"
The ones from "Marti" are not complete rivets. No instructions from "Marti" so I used my own rivets. I can't tell the difference from the front.
Besides doing it my way the plate won't fall off It's on tight like it should be.
So what gives?
Old Jan 10, 2021 | 05:46 PM
john jamieson
Thanks for the replies. I think I will just use regular rivets, since I have them
Old Jan 10, 2021 | 06:38 PM
skidoorulz's Avatar
skidoorulz
So what gives?
I would know. But with that said mine are pop riveted because when I redid my truck those were not reproduced and NOS ones were going for big money and even though I had big money in my truck I couldn't quite bring myself to pay for them. Now that they are down to 1.50 I may splurge.
Old Jan 10, 2021 | 07:16 PM
gangstakr's Avatar
gangstakr
Before you buy any look at these. The two newer ones came from "Marti" The two older ones I removed from the old tag.
The ones from "Marti" measure 1/8" just barely enough to go through the plate and door. I thought long and hard as to how to attach and get a good solid squeeze to make sure data plate does not fall off. So I will keep them in a envelope in the door pocket.
Old Jan 10, 2021 | 07:19 PM
skidoorulz's Avatar
skidoorulz
If you were to stick the new ones just thru the tag how mush would be stiking out the backside?
Old Jan 10, 2021 | 07:22 PM
53deere's Avatar
53deere
Thanks for posting that. I was going to buy some from Marti but I think I'll just use pop rivets now. Maybe if I was doing a restoration but my truck is modified so I'll go with secure instead of correct.
Old Jan 10, 2021 | 07:48 PM
gangstakr's Avatar
gangstakr
Not really sure. When I put them through the tag and through the door it barely went through.
Old Jan 10, 2021 | 08:13 PM
jacobn936's Avatar
jacobn936
I bought a new tag from Marti. It came with the rivets and they worked like a charm.
Old Jan 10, 2021 | 08:50 PM
gangstakr's Avatar
gangstakr
How did you attach the rivets? As you can see in my picture there isn't a way to use a rivet gun, so what did you use?
Old Jan 10, 2021 | 09:15 PM
skidoorulz's Avatar
skidoorulz
I have been told the original ones had what I would call blisters just like your reproduction ones. They would stick them in the hole and they had a small punch the size a little smaller than the inside diameter of the hole and they would tap the punch wit something I assume a small hammer and make the blister a dimple causing the sides to flare out.
Old Jan 11, 2021 | 08:13 AM
jacobn936's Avatar
jacobn936
I stuck them in the hole then used a small punch to punch out the center. I cant remember what size Marti recommended, but it worked like a champ. I have been thinking about this and I think Marti recommended using a 9/64th bit as a punch.
