Wastegate Control Valve Performance code
Old Oct 25, 2003 | 01:15 PM
dirtroaddevil's Avatar
dirtroaddevil
My truck recently pulled a code when i checked it with my diablo predator tuner. Does this meen that the wastegate is not performing right or that ist is working to much? Help
Old Oct 25, 2003 | 11:18 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
What was the actual code? Like POxxx.
Old Oct 27, 2003 | 01:31 PM
bazzer's Avatar
bazzer
You best ignore it. I have the same problem and I have been told that the code is normal because the Diablo Predator puts out more boost than the factory specs, you might even see your "Check engine" light come for a short period. Obviously, if the light comes on and won't go away you should get it check out by a repair shop.
Barry
Old Oct 27, 2003 | 07:10 PM
dirtroaddevil
thanks guys. I cleared the code and it hasnt reappeared yet.
Ryanizbrand
Mar 27, 2017 05:56 PM
Ryanizbrand
Testing.....
Mar 27, 2017 05:08 PM
blksiryder
Aug 22, 2007 09:06 PM
sgrol
Apr 12, 2007 09:38 PM
