Coolant hose diagram
Old Jan 8, 2021 | 06:26 PM
eric8's Avatar
eric8
Can anyone get me the parts breakdown (factory illustration) of the radiator and hose assembly. Specifically, I'm trying to see how the factory shows the lower radiator hose on a 71 F100. 302 engine, m/t, no a/c, but with factory extra cooling radiator. I have the correct molded lower radiator hose (according to Gates) and it just isn't fitting right. Tried installing it in both directions and not pleased with the fit.
Old Jan 8, 2021 | 08:45 PM
RichS2659's Avatar
RichS2659
Is it too long? Generally I think that some have to be cut off to fit sometimes.
Old Jan 10, 2021 | 03:58 PM
eric8's Avatar
eric8
It does seem a little long. And it will fit (poorly) both ways. I assume the "s" shaped end goes on the water pump outlet to clear the a/c belt or pulley. I'm getting 2 3/4" across the top of the radiator assuming I'm measuring it correctly, which would indicate I have the extra cooling factory radiator.
Old Jan 12, 2021 | 04:21 AM
GaryKip's Avatar
GaryKip
What is the height and width of the radiator?
Old Jan 12, 2021 | 03:41 PM
eric8's Avatar
eric8
I'll have to get back to you with that on Friday as my radiator is at the shop getting cleaned and a pinhole soldered up. According to my factory service manual though, both the xtra cooling and standard radiators are the same length and width. Only the thickness is different.
Old Jan 13, 2021 | 07:19 PM
JEFFFAFA's Avatar
JEFFFAFA
The shorter side of the "L" does go to the water pump. And 2X Rich, aftermarket hoses are "cut to length". Either end or both.
AAubinoe
Mar 19, 2020 10:04 AM
carpe_diem
13
Aug 11, 2019 06:05 AM
duckdaddy
Modular V8 (4.6L, 5.4L)
Aug 13, 2014 01:30 PM
brokenjack
Aerostar
Jul 29, 2012 12:55 PM
teamlx88
Aug 9, 2010 03:59 PM
