2010 Expy 5.4
Old Jan 8, 2021 | 04:48 PM
2012 F150 5.0's Avatar
2012 F150 5.0
2010 Expy 5.4
Just picked up 2010 Expedition with 5.4; and 4WD. 122K miles. Ex Sheriff rig. There is a clear noise on the right side on start up which goes away after a couple of minutes. My mechanic thinks left exhaust manifold leaks and quiets after the parts heat/swell. However, I was crawling around under the car while it was running, and this noise sounds more metallic, like its in the engine. Like a lifter not getting pumped up. So what is the most likely failure mode on the 5.4(3V I think)? It runs good; idles smooth. Just put 800 miles on it at 70mph and it did about 16.2 with 3.73 rear end.
Old Jan 8, 2021 | 07:55 PM
Johnny Paycheck's Avatar
Johnny Paycheck
If it’s fixing to have timing chain issues, those chunks of chain guide clogging up the oil pump pickup will cause some valvetrain wear.
Old Jan 10, 2021 | 05:03 AM
JWA's Avatar
JWA
Have you checked the actual oil pressure with a real gauge and not that thing inside the instrument cluster? That might be extremely helpful.
kactus_kyle
Oct 30, 2017 05:09 PM
secondechomatt
Modular V8 (4.6L, 5.4L)
May 30, 2010 06:26 AM
StretchRcr
1997 - 2003 F150
Mar 18, 2005 01:05 PM
smmuttyy
Mar 25, 2002 05:34 PM
