Front U Joints
Old Oct 25, 2003 | 09:20 AM
Bigchudman's Avatar
Bigchudman
Front U Joints
Hello I have looked on old forums for how to change my front U-joints and it seems that I cant find the how to part of it. I have a 91 ford 4 wheel Drive . The question mostly is do the axles come out once the rotor is removed ?
Old Oct 25, 2003 | 04:59 PM
yellowjeep76's Avatar
yellowjeep76
i believe that there is a spindle that you also have to remove. just get you a good manual to help you out. it will give you all the correnct numbers for torque specs.
Old Oct 25, 2003 | 09:33 PM
BigNateK's Avatar
BigNateK
yeah you have to pull the spindles offand the the whole shaft will pull through the srearing knuckle. the u-joints on the axle shafts have the clips on the inside of the yokes. hope that helps ya
Nate
