Levelling kit
Old Jan 3, 2021 | 03:35 PM
Powerstroke2000's Avatar
Powerstroke2000
Levelling kit
I'm wondering if many here have done a level kit on their truck? The 2" & 2 1/2" seem to be the most popular, and since I have air bags on my F150 which adds an inch more or so (than stock) I'm thinking of the 2 1/2" kit. Was thinking about doing the job myself, as there are some Youtube video's on the process, but there are a few unique tools I may not have, including a torque wrench that goes above 100 ft. lbs, as that's where my torque wrench stops! Next set of tires I may go larger too, albeit not 'too' much, to help fill in the wheel well space.
Old Jan 3, 2021 | 03:48 PM
NASSTY's Avatar
NASSTY
I would only add a level kit if I was definitely going with larger tires. Stock tires already look small on these trucks and when you raise the truck at all the stockers look like donut tires.
Old Jan 3, 2021 | 05:44 PM
jake415's Avatar
jake415
If you are going the spacer route, DIY isn't too bad. But if you go with longer than factory struts like Bilsteins, they are a PITA according to the tech that installed my Bilsteins. He said they were no fun at all and that is definitely not a DIY project. I am very happy with the ride and stability of a leveled truck with Bilsteins. Much better ride in every aspect than stock shocks and struts with spacers.
Old Jan 3, 2021 | 06:39 PM
Powerstroke2000
Thanks! Yes, I did contact a local high end shop, and they only do it via the Bilstein install way, and of course was much more expensive than going the stock & spacer route. They thought going with Bilsteins in the rear would be a good option as well! I believe here in Canada it was about $1200.+ going with the front Bilstein option and Bilsteins in the rear. Lots to think about before jumping in!
Old Jan 4, 2021 | 12:28 PM
99powerstrokedF250's Avatar
99powerstrokedF250
If you want or need the extra articulation, then something like the Bilsteins is a must. If, like my wife, you just want the look and the extra articulation isn't necessary (we have the PowerWagon for that), then spacers are a very economical way to do it. It sounds like you want the extra articulation, so go for it!
Old Jan 4, 2021 | 01:26 PM
JKBrad's Avatar
JKBrad
This is how I see it. Brand new truck, use spacers. Makes no sense to get rid of brand new shocks. A trucks that’s a few years old and needs new shocks anyway, go with a set of coil overs. Since you have a 2016, that may be the way to go.
I put 2.25” ReadyLift spacers on mine when it was nearly new. Zero issues and a great ride for 5 years and 50k miles. Soon it will be time to consider new shocks. Bilstein 6112s are at the top of my list right now with HaloLifts running second.
jake415's Avatar
jake415
I never gave much thought to articulation, but I will say that if I could turn back the clock to the day I bought my truck, the very first thing I would have done is put Bilstein 5100's on the rear, and next thing would have been 6112's on the front. Ford shocks are terrible compared to Bilstein. I would consider shock replacement a must.
Old Jan 4, 2021 | 01:35 PM
jake415's Avatar
jake415
JKBrad, if you think the OEM shocks offer a great ride, you are in for a shock! Haha, pun intended! Try Bilsteins on the rear for $188 pair and 15min to install. Then head to the nearest railroad crossing and tell me you didn't kick yourself for not doing it sooner!
Old Jan 4, 2021 | 02:05 PM
JKBrad's Avatar
JKBrad
I don’t doubt you. But then again I have a 157” wheelbase with Max Tow, which makes a big difference in the ride. I will get new shocks In the not too distant future and I will see the light I’m sure. But I have to say, my truck does ride nice as is. I have noticed that if I turn a corner sharp or take a curve on the highway at speed, the shocks are getting noticeably soft, so that’s my big motivator right now.
Old Jan 4, 2021 | 02:19 PM
jake415's Avatar
jake415
Interesting. My experience with OEM shocks in comparison to Bilstein is that OEM shocks are soft when they need to be firm and firm when they need to be soft. Its almost like they put the valving in backwards! LOL
And your description of the OEM shocks being soft around curves etc is spot on. Way too much lean. Also, the OEM rears don't like rough roads, railroad tracks, and potholes either. The Bilsteins fix all that. Now my truck handles more like a Mustang in the curves, and doesn't kick like a mule over potholes and RR crossings. Increased stability during trailering is also vastly improved.
Old Jan 4, 2021 | 03:19 PM
Jafo56's Avatar
Jafo56
I too have the 2.25" ready lift up front.....also a 3" block in the back (factory block removed)..... stock shocks that will be replaced with bilsteins when the time comes.....
Old Jan 4, 2021 | 03:25 PM
JKBrad's Avatar
JKBrad
One major difference in our driving experiences is that here in South Texas, the roads are mostly smooth. There are no expansion joints or frost heaves to deal with.
Old Jan 4, 2021 | 04:06 PM
CR172's Avatar
CR172
I just installed 5100's in the rear of my leveled truck. I will agree the ride is better, firmer without being harsh and the truck feels much more planted to the ground. But with that said, my truck never gave me the "tail end trying to catch the front" scenario on bumps or railroad tracks.
jwc410
Jan 31, 2017 02:07 PM
pin8246
13
Aug 7, 2012 11:29 AM
Onebadpolaris
Modular V10 (6.8l)
Jan 6, 2008 03:36 AM
Johnnyboy04
2004 - 2008 F150
Sep 3, 2004 05:59 PM
