Code 41 OBD1
Old Jan 2, 2021 | 11:31 PM
Greg-93’460's Avatar
Greg-93’460
Code 41 OBD1
So long story short, truck tripped code 41.
1993 f250 w/ 7.5. 148,xxx miles
HEGO no code detected
or lean code detected.
My sensor wires looked fine when I crawled under there. is there a way to test the sensor before taking it off the truck? And replacing it if that’s not the problem?
My truck has terrrible mileage as in 1/2 tank per 60 highway 😬🤷‍♂️
Another thought would be a vacuum leak somewhere introducing unburnt oxygen into the line.
Another, nother thought would be a cylander not firing for some reason and releasing unburnt oxygen down the line? I tried to do the cylander balance test but I don’t have that option since it’s so old
No MAF, I don’t think so. there’s no input of oxygen on the front end.
All trouble shooting ideas welcome! Got a decent trip with truck maxed out with shingles next weekend and would like to get better mileage over the mountain if I can.
Old Jan 3, 2021 | 05:45 AM
torq'ta 5 8's Avatar
torq'ta 5 8
crack in exhaust manifold, happens on 460's a lot, besides, vacuum leaks.
supposedly you can-->Oxygen Sensor Information
Old Jan 3, 2021 | 10:25 AM
Greg-93’460
Thanks for the link 👍🏻👍🏻
I was thinking back to high to high school science class when I heard something about diffusion. There’s no “membrain” in our situation but the high pressure in the manifold & exhaust and the low pressure outside. How would oxygen get inside the exhaust?
So my solution would be to find the leak/crack upstream and seal it with tape/puddy etc. any downstream leaks don’t matter.
Old Jan 3, 2021 | 10:31 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That is a short term “Band - Aid” fix at the most. The real solution is to replace the broken manifold.
Old Jan 5, 2021 | 08:37 PM
Greg-93’460
any idea where the exhaust cracks typically are on 460’s?
I smoke tested the exhaust and it leaked like sieve from the drivers header/Y pipe connection but nothing else Pre-o2 sensor.
Slathered puddy on that seam and waiting for it to dry. I’ll do a second test smoke tomorrow night. Just wondering if there’s any other typically rust holes or leaking areas.
Old Jan 5, 2021 | 09:35 PM
Conanski's Avatar
Conanski
Single or dual tank? If dual do both work?
What is the fuel pressure at the motor with the engine running?
Old Jan 5, 2021 | 10:04 PM
Greg-93’460
duel tanks and both work.
I need to replace pumps I think because I have a hard starting issue where it doesn’t maintain pressure after turning off.
Just replaced regulator 4 months ago. Pressure was at that time 25 at idle and 30 WOT.
Would an an issue with that be connected to a 41/ o2 CODE?
Old Jan 5, 2021 | 10:39 PM
Conanski's Avatar
Conanski
Yeah that pressure is way low, there should be 32-35psi at idle with vacuum attached to the pressure regulator, and any time the throttle is blipped(not held) or the engine is under load(low vacuum) pressure should rise. With vacuum removed from the regulator you should have 39-45psi.
A common problem with dual tank trucks is fuel transfer between tanks due to faulty or stuck control valves in the FDM inside the tanks. If the inactive tank is full to begin with the active tank will overfill it and spill fuel on the ground as you drive, making the fuel consumption look horrific. If there is a smell of raw fuel immediately after parking this could be a problem, look at the bottom of the full filler neck on the unused tank to see if it is wet.
Old Jan 5, 2021 | 10:44 PM
Greg-93’460
i should re-test it. I remember it being within spec when I tested it.
Is this connected to CEL #41?
Old Jan 5, 2021 | 11:45 PM
Conanski's Avatar
Conanski
Yes if pressure really is that low.
Old Jan 9, 2021 | 07:57 PM
Greg-93’460
Good news everybody
ran over the mountain 85 miles fully loaded 9,000lbs and had no check engine lights pop on.
Forgot to bring my code reader to see if there was pending but typically the CEL would pop on within 20 miles.
replaced the O2 sensor and files the gap between the header and Y-pipe.
Didnt have time to try one solution then the next if the light came on after the first fix. 👍🏻👍🏻
Iceman1777
6.7L Power Stroke Diesel
Aug 14, 2025 02:44 PM
Ben34
1997 - 2003 F150
Feb 11, 2012 05:21 AM
kellysteed
1997 - 2003 F150
Jul 20, 2010 01:56 PM
amerimutt
1997 - 2003 F150
Aug 1, 2009 01:18 AM
bgblktruk
1978 - 1996 Big Bronco
15
Aug 8, 2005 07:47 PM
