2002 Electronic Climate Control
Old Jan 2, 2021 | 11:33 AM
jd58980's Avatar
jd58980
2002 Excurion,
Anyone have the electronic (digital) climate control get stuck on Hot? Does the system ever go bad?
Have changed the blend motor twice and all I get is hot air out of the system?
Old Jan 2, 2021 | 01:26 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Jim have you looked at the 4x4 vacuum solenoid located near the battery just above the vacuum pump. It has an electrical hook up along with a vacuum connector, it cracks underneath and causes it to malfunction. It controls the air flow in the cabin along with the 4x4 hubs Mine was broken and caused my system to continuously switch from vent to defrost. 40 bucks later , fixed. You can also preform a diagnostic test on the eatc
Old Jan 2, 2021 | 02:15 PM
jd58980's Avatar
jd58980
All the vacuum stuff works fine.
But, the a/c and/or heat blows HOT no matter what I set the temp at, through the defrost, dash vents or floor.
I have no Temperature control....
Old Jan 2, 2021 | 05:54 PM
Vinny G-the EX man
Try the EATC self test to try and pinpoint the problem
. Hope this helps
Old Jan 2, 2021 | 08:02 PM
jd58980's Avatar
jd58980
Originally Posted by Vinny G-the EX man
Try the EATC self test to try and pinpoint the problem https://youtu.be/hAqE-oYnvlQ. Hope this helps
Thanks Vinny, will do the self test in the morning.
Old Jan 3, 2021 | 10:52 AM
jd58980's Avatar
jd58980
thanks Vinny, codes came up as 22 with degree symbol and little e and 66
Researching it says left blend door.
This does not have dual air, so my guess is blend door is having issues?
Old Jan 3, 2021 | 11:33 AM
Vinny G-the EX man
That sounds correct, not sure it was you but didn’t you find a lose wire behind the glove box ? Could be a clue, good luck, at least you know we’re to look.
Old Jan 3, 2021 | 11:56 AM
jd58980's Avatar
jd58980
have blend door cover off and relooking at actuator. Testing actuator, the door actuator does not move when I adjust the temp, thinking I have a blown fuse but cant find any info what fuse it could be?
Any ideas.
DavenTn
Dec 7, 2020 08:48 PM
DrDerekReiser
1997 - 2003 F150
Mar 3, 2019 11:27 PM
kev03
Jun 17, 2008 04:56 PM
RonM
1997 - 2003 F150
Apr 29, 2005 01:28 PM
