Electronic Climate control
Old Dec 7, 2020 | 06:15 PM
DavenTn's Avatar
DavenTn
2002 Excursion LTD. Looks like my electronic climate control assembly has failed. If anyone knows where to get replacements other than ebay... please let me know. Apparently no longer available from Ford. .... or if you could recommend a reputable refurbisher/rebuilder. Thanks
So far... I've found most refurbishers are 'out of stock'.
Old Dec 7, 2020 | 06:29 PM
william_04_x's Avatar
william_04_x
https://circuitboardmedics.com/ford-other/
Scroll down to find the EATC, and see if yours fits their description(thumb wheel fan control).
Old Dec 7, 2020 | 06:43 PM
DavenTn's Avatar
DavenTn
Thanks... but mine is different.
Old Dec 7, 2020 | 06:51 PM
EXSwap's Avatar
EXSwap
Not for nothing, it did you try the cycle your headlight switch trick?
Old Dec 7, 2020 | 06:55 PM
DavenTn's Avatar
DavenTn
No ... and I'm not exactly sure what that is.
Old Dec 7, 2020 | 06:58 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
I recently replaced mine with a rebuilt that I purchased on eBay for 249 no core Buy the way what is wrong with yours.
Old Dec 7, 2020 | 07:02 PM
DavenTn's Avatar
DavenTn
Well that's a good question.... since I don't have my truck right now, My kids do. I'll have it back tomorrow. It seems there's a vacuum leak (the gray line) at the unit and the display goes wonkie at times... not always.
Old Dec 7, 2020 | 07:25 PM
Vinny G-the EX man
I struggled with my AC defaulting to the defroster and then switching back to the vents for years (at least 10) as I tried to find the problem to no avail. I finally found the problem, the 4wheel drive solenoid which is located on the passenger fender near the battery. It was cracked on the bottom and was causing a vacuum leak, although my 4x4 was working it was enough to affect the the climate control. Forty bucks and I was back in business.
PS: My EATC is electronic and does not have any vacuum lines attached
Old Dec 7, 2020 | 07:37 PM
DavenTn's Avatar
DavenTn
My 4WD solenoid is brand spanking new. I've had a minor vacuum leaking at the gray line... everything else is tested and good. Probably an o ring somewhere... but the electronics "according to my kids" is an issue. I'll know more tomorrow.
Old Dec 7, 2020 | 08:48 PM
EXSwap's Avatar
EXSwap
Sometimes they don’t work, and with your X running, cycle the headlight switch on and off a few times. There’s a relay in the dash that sticks and that should (if that’s the problem) make it start working again. I’ve not seen an actual fix for this problem, but mine does it from time to time.
Xwarrior86
Ford Truck Parts for Sale
Jul 18, 2017 04:38 PM
Apocalypse
Apr 3, 2013 08:54 AM
HUBBSTER
Jan 16, 2012 08:55 PM
