Blown head gasket.
Old Dec 31, 2020 | 10:22 PM
dremtofford's Avatar
dremtofford
Blown head gasket.
the truck has over 100,000 miles on it but other then the white smoke and high idle it runs great. Should I put new rings and bearings when I rebuild it. Or go for a short block and rebuild the heads? The truck won't get run much just around town.
Old Dec 31, 2020 | 10:27 PM
hobohilton's Avatar
hobohilton
What engine are you dealing with ?
Hobo
Old Jan 1, 2021 | 12:24 AM
dremtofford
Blown head gasket
It is a 88 5.0 liter.
Old Jan 1, 2021 | 12:53 AM
Bignasty2's Avatar
Bignasty2
There's a good chance that smoke is coming from your valve seals and it's not your rings at all. The cheapest would be new valve seals yourself and no machine work. Seals and head gasket probably under $40. If your truck isn't getting run hard, you'll probably get away with it for a good amount of time. THEN ... You could find a cheapo junkyard pull or craigslist deal and spend time doing things right at your own pace and budget and still come in cheap. How much do you love it? Any idea why the head gasket? This should be addressed as well.
Old Jan 3, 2021 | 03:55 AM
dremtofford
Blown head gasket
the smoke is white and the truck uses water. It was neglected by the previous owner who told me he wasn't a mechanic. I am slowly fixing things up on it as I get the money pretty soon I am going to have to fix the clutch and I think the head gasket, then I will learn about painting and body work.
Old Sep 3, 2022 | 11:13 AM
dremtofford
it was a blown head gasket and a burned valve on the driver's side. got that fixed now to check the passenger side. by the way, had loose bolts all over the place. 4 bolts on the lower intake were tight the rest were just sitting there. got all the exhaust bolts out without breaking with a 1/4 in ratchet the head bolts were taken out with a 3/8 rachet.
Facelift
Aug 19, 2015 09:22 AM
Tomget
Apr 18, 2015 05:45 PM
operator exmark
Oct 27, 2006 06:50 AM
