Sneaky Leaky 6.0
Old Dec 31, 2020 | 01:34 AM
GrinAndBareit's Avatar
GrinAndBareit
Sneaky Leaky 6.0
I have coolant leaking from the top of the engine in the back somewhere but I can't find the source of the leak. It's a 2003 6.0 F250 Crew Cab. I even pulled out the turbo and wasn't able to find any leaks. I thought it may have been the little blue hose from the oil cooler to the EGR cooler because it was turned 90 degrees counter clockwise so I turned it back a quarter turn to tighten it. Apparently that wasn't the leak. Now I can see it dripping off both sides of the block where before it was just the passenger side I could see. I've used my phone camera, mirrors, and removed the turbo to try and see it with no luck. I just got done putting it back together and am unable to afford a mechanic at the moment since I just spent 3 grand on injectors and am unemployed until the pandemic is over. I missed out on my big opportunity to invest in Bitcoin and now it's skyrocketing to unaffordable prices. If you have money I strongly suggest you buy as much Bitcoin as you can afford. I promise you will not be disappointed. It's gone up almost $20k in 4 months and I am sure it will hit $250k by the end of 2023. I bet my life on it getting close to that mark. If anyone decides to invest and you make a fortune on my advice you can send a tip to my Bitcoin wallet address listed below. Any donations are greatly appreciated. I love my truck and I need it fixed. Is there a freeze plug hidden on top of the block under one of the pipes or something? Please any suggestions might help. Thanks guys!
3MvxgEnF6FGexZVq9KZhEvpyZGtXgwaSXv
mgpsfan
Colorado Chapter
Oct 4, 2017 07:07 AM
Lovin7.3
Nov 15, 2011 09:36 PM
ColumbiaFord
Jan 9, 2011 09:03 PM
uncwgrad1
Jan 14, 2010 02:32 PM
03F350GUY
Dec 27, 2009 04:13 PM
