Having hard shift problems with E40D after rebuild...any info or links would be appreciated. Would like to know where speed sensor is? I think its an electrical problem...
91 Bronco Eddie B
F350 10.25 5.13 rear end (great brakes and easy swap)
ARB Air Lockers
38" TSL radials
9" leafs in back
6" springs in front
3" body
ARB bumber (easy mod to accom 3" body just grinding)
12000# warn
custom traction bars (started as Fabertech)
Alum radiator
Going to electronic fan per Brian Soderbloms web site.
there is a sensor in the rear end
there is a sensor in the transfer case
which one goes to ABS and which one goes to the transmission computor ....who knows
put in new mlps and shifts from 1 to 2 a smooth...still have some what of hard shift from 2 to 3 and OD. I think I'm going to replace the TPS next. Speed sensor is on the list...which there was a good way to check it out...
