1978 - 1996 Big Bronco
jumping when shifting gears (auto)
Old Sep 20, 2003 | 07:36 PM
Broncobigtire's Avatar
Broncobigtire
Ok...As of now I have spent about 4000 dollars on trying to fix a problem and it pissing me off really bad...when im axcelerating normally when the tranny (E40D) shift from gear to gear..the bronc sort of jumps or doesnt shift smoothly..as of now i have replaced the tranny, new ecm, shift linkage...i was wondering if yall knew of any other stuff i should look at...i would like to know what is freaking wrong!!!...thanx a ton
92' Bronc Custom, K&N, bassani full exhaust
Old Sep 20, 2003 | 08:51 PM
89broncobob's Avatar
89broncobob
cought be the converter
Old Sep 20, 2003 | 08:52 PM
89broncobob
or some thing as simple as the tranny mount .but you would have some vibration with that
Old Sep 21, 2003 | 08:42 AM
Broncobigtire
what do you mean by the converter...torque converter?
Old Sep 22, 2003 | 04:51 PM
sluggslime's Avatar
sluggslime
what other symptoms are you having? is your speedometer needle jumping? Is your abs light on? do you have a poor signal code from the vss in the tranny? I am currently replacing the instrument cluster on my 92 bronco because of the PSOM inside the cluster. The dss in the rear diff sends a signal to the PSOM, the PSOM then sends the signal to the vss in the tranny and also to the abs module. if the PSOM is bad, then problem shifting occurs, along with the other symptoms.
Old Sep 22, 2003 | 05:27 PM
Broncobigtire
what is the PSOM?...i have already replaced dss but im not sure about the vss...where is it located..i think i thought it was at the end of the tranny that goes into the tranfer case??
Old Sep 22, 2003 | 05:35 PM
sluggslime's Avatar
sluggslime
the PSOM is programable speedometer/odometer module and it is located inside the instrument cluster. You are correct, the vss is at the end of the tranny that goes into the t-case. It should be on the top and a little hard to get to but I have yet to replace this part myself, though I already purchased the new one.
Old Sep 22, 2003 | 05:47 PM
sluggslime's Avatar
sluggslime
another thing to look at is the MLPS if the symptom is only transmission related. (manual lever position sensor)
Old Sep 23, 2003 | 10:24 AM
Broncobigtire
ok...when i bought the new tranny i got a new mpls sensor thing..so i guess i will have to buy the vss...how much did it cost you??...hopefully not much b/c ive already spent enough money
Old Sep 23, 2003 | 02:25 PM
sluggslime's Avatar
sluggslime
here is the thing... i thought that the vss went in the t-case, i was wrong. when i went in to purchase the vss they gave me one with a speedometer cable connector but the instrument cluster does not use a speedo cable then it hit me the e in e4od is for electronic, hence the need for a mechanical device such as the speedo cable. I went back and asked to exchange it for an abs speed sensor, in the rear dif bell housing. It cost $32.00.
Old Sep 25, 2003 | 11:44 AM
abellma's Avatar
abellma
I have a '94 5.0L with E4OD transmission. I had similar symptoms to Broncobigtire. I purchased a code reader ($25 from Walmart) and kept getting a code 452 - poor Vehicle Speed Sensor (VSS) Signal.
This is what the Ford dearlership did:
(1) Replaced the speed sensor which is housed in the rear differential. Did not fix the problem.
(2) Repalced the ABS module after pulling some bad ABS codes - the signal from the sensor goes through the ABS before it gets to the transmission. Cost $$$ and did not fix the problem.
(3) Finally they replaced the Programable Speedometer/Odometer Module (PSOM) and did some other work for free (I told them I suspected the PSOM from the start). This, at last, appears to have fixed the problem. I am no longer getting the erratic/hard shifts and I no longer get 452 codes.
Old Oct 24, 2003 | 10:07 PM
spike2's Avatar
spike2
sound like you have been fighting a problem I've got.....hard shifts
The E stands for Extra hard to fix.
I have a 91 Bronco which I do not believe has the PSOM module
Any suggestions on where to get electrical diagrams.
Sounds like you've done some digging....
Old Oct 25, 2003 | 01:26 PM
GeoTracker's Avatar
GeoTracker
I've got a 90 with a E4OD and I too have some hard shifts but they only occur under hard acceleration. If I take it easy off the line then the tranny will shift fine. Usually I get a real nasty clunk when it tries to shift. It almost feels like the tranny dropped out of the vehicle.
Old Oct 29, 2003 | 08:19 PM
spike2's Avatar
spike2
I just put a MPLS sensor on the trans....FORD wanted $107 and I talked them down to $72. It had the connector conversion kit which was a little painful to install. I used a small 1/16 x 1/16" silver solder stick to release the pins in the old connector. Was easy once I got the hang of it. Light pressure was only needed to pull the wires/end out. It really staighten out the 1-2 shifts but 2-3 and 3-OD still harder than I like. I'm going to replace the TPS sensor next...Quote $42 for sensor. Will let u know the outcome..under acceleration like mine and yours will probably be the TPS.
Old Oct 29, 2003 | 08:21 PM
spike2's Avatar
spike2
oh yea check your u joints....they can clunk under load....
lonewolf78
Oct 31, 2013 09:02 PM
hoytshooter119
Oct 27, 2011 02:05 PM
az4x4bronc
Apr 8, 2007 10:50 PM
68 351 bronc
Apr 2, 2004 11:22 PM
