2000 Excursion Tail Lights
Old Dec 29, 2020 | 04:58 PM
BlackWolf2000's Avatar
BlackWolf2000
I have been having issues with the rear lights. My mechanic can not figure it out. All of the rear exterior lights do not function properly and operate at all different times with the wrong controls. They traced the wiring to the neutral safety relay switch and to the rear wiring harness and found them corroded and they repaired the connections. However, it is still doing what the lights wants to do afterwards. This is driving us crazy. I hope someone has encountered this and had it fixed.
Old Dec 30, 2020 | 12:48 AM
Lance Helmert's Avatar
Lance Helmert
I would check the grounds. I think there are some back by the tail lights and I know there are a bunch in the engine compartment. Bad grounds make lights do strange things.
Old Dec 30, 2020 | 06:32 AM
projectSHO89's Avatar
projectSHO89
There are no pertinent details contained within your post that would allow any substantive assistance in troubleshooting and it appears you are not technically astute in this matter.
Find a mechanic/technician who understands electrical diagnostics and hire him/her to fix it.
Old Jan 4, 2021 | 04:49 PM
SteveZ's Avatar
SteveZ
^^^^This is the kind of answer that drives people away from forums and gives them a bad name.
Maybe you should not respond if you are not going to be helpful or protect your Cheerios from being pissed in before posting.
Old Jan 4, 2021 | 05:11 PM
SteveZ's Avatar
SteveZ
Black wolf can you give any more information on what the lights are actually doing? Are the going out and coming on intermittently? Are the turn indicator staying on solid instead of flashing? Reverse lights on even when not in reverse Ect ect? A better description would help narrow down where to look.
Some additional information on the truck may also be useful. Was it ever flooded or have any water leaks. Any major accident that may have pinched wires. Do you live in an area that has lots of salt in the air, salting the roads for snow in common, lots of boat ramp time.
Lance is pointing you in a good direction with with the recommendation to start looking at grounds.
ProjectSHO was on to something with both of his points. More information would be a big on helping you narrow down the problem. Also not all mechanics are great at electrical problem. You may want to look for a mechanic that has a good reputation for electrical problem repairs.
Old Jan 4, 2021 | 05:15 PM
projectSHO89
Tough.
Sometimes you just have to tell someone that they are out of their field of competence and to get expert assistance from someone who can assist them hands-on. Sometimes, the coach has to order a punt even when the team wants to go for it on 4th and long.
Old Jan 4, 2021 | 06:56 PM
Rainmaker1's Avatar
Rainmaker1
I agree with Steve.. I've posted many questions that were "out of my league" to simply educate myself when I do bring my truck to a mechanic. I want to know what they are doing. Furthermore Mr. projectSHO89, do you have an Excursion? Your signature line indicates otherwise. So, who is out of their league?
If I may offer some constructive advise, It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt.” - Mark Twain
Old Jan 4, 2021 | 07:26 PM
SteveZ's Avatar
SteveZ
There is another thread from a couple of days ago that may be helpful.
https://www.ford-trucks.com/forums/1...ng-issues.html
WV2004
Apr 11, 2013 02:09 PM
choptop49ford
Electrical Systems/Wiring
Aug 26, 2012 10:29 AM
1bad67sbf
Mar 28, 2010 11:56 AM
crestfallinman
May 17, 2008 11:22 PM
