converting to carbaurator
Old Dec 29, 2020 | 03:59 PM
Will Joyce's Avatar
Will Joyce
Have a 302 in my 87 F150 now - Have a 90 something 351 windsor in my garage - Want to convert the 351 to a carbaurated engine -
dont think a 302 maniffold will work on a 351 .Is that correct ? I think I need the dizzy , wiring harness, -
Have any of you done this or is there a link you can direct me to
Thanks Will
Old Dec 29, 2020 | 04:15 PM
SFaulken's Avatar
SFaulken
No, it will not. The Deck height on the 302 and the 351W are different, which makes the intake manifold for a 351W wider than the 302.
Old Dec 30, 2020 | 11:00 AM
rla2005's Avatar
rla2005
Why go back to the stone age?
You are correct. The 351W deck height is taller than the 302, which makes the distance between the heads is wider.
You are correct
wiring harness, -
No, keep the harness that is currently in the truck.
There are hundreds of posts on the 302 to 351 on this forum. Do a search and read up on the subject and possible pitfalls.
Old Dec 30, 2020 | 11:19 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What he said. A “ ‘90 something” 351 would be fuel injected from a truck so you have all the parts? Why not just swap the 351 for the 302 and be done with it?
rcgrady
Apr 18, 2005 04:16 PM
javi2001
Sep 20, 2004 04:38 PM
Danos-f150
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 19, 2004 12:37 AM
drmmr67
Sep 4, 2001 11:31 PM
