Disagree entirely on two of three of your criteria and so does the FAA. The debate rages and I'll just submit this final little tidbit "A wire, in order to be effective, must be secured to a reliable connector at each end. In aircraft, electrical connections are made using insulated crimped terminals"
Like we always say "If its good at Mach II its good for you"
Aircraft take a beating and are subject to way worse extremes than a truck ever will... the only thing I will add onto the point of crimping is a bit of dielectric grease never hurts.
I have seen more bad crimps than I ever have brittle/broken solder joints. Not arguing with those who know better; too, I seldom fly my truck.
Ditto. Not a fan of crimped connections either, but we have to rely on them at every wire terminal on the truck. Solder joints can still fail too. That's why I prefer the cheap and simple way of just twisting the wires together real well, (assuming stranded wire such as speaker wire) and putting on some heat shrink, and calling it a day. No third component to fail. Only my work on the wire, and the replaced insulation, are there to potentially fail.
The problem with soldered connections in an automotive environment is that they will corrode and degrade much more quickly than a properly crimped connection. Ever see soldered connections in factory automotive wiring? In my 45+ years of working on cars, I haven't. Ever see a soldered connection in home or commercial electrical wiring? Of course not. The Electric Code requires mechanical connections, because they're far more reliable than soldered connections. A good mechanical connection is infinitely better than a soldered connection. To get a properly crimped connection, however, you need the proper tools, and most people don't have them. That's why the average Joe's crimped connections don't last. Do it right, and it will do you right.
Those molded in lumps in factory Ford harnesses are crimped and soldered connectors and molded inside rubber. Have taken apart several harnesses rebuilding hacked up Mustangs and pickups. But in general the factory just crimps connectors but with excellent tooling not the kind you get in the $10 box with 50 blue plastic butt connectors.
