Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
road noise
Old Mar 28, 2005 | 03:59 PM
1984 f-250's Avatar
1984 f-250
I have the Continental tires too. I have 36500 miles and i already need to replace them but from expirience with my explorer I will be putting toyo tires on my escape as well.
Old Mar 30, 2005 | 08:06 PM
bill mcgough's Avatar
bill mcgough
I had my 05 ESCAPE 4WD V6 road tested for excessive noise by an experienced certified mechanic. Results as follows:
1. There was increasing tire noise from the Continentals as speed increased. Recommendation was to find more quiet tires. No particular brand.
2. Engine (Duratec V6) makes noise at both slow and fast speeds when accelerating because head appears to be plastic(black plastic, just take a look at it). When engines were cast iron, this sound did not exist but now, the intake air creates an increasingly louder noise as it passes through the head.
3. Both tire and engine noise under the hood can be heard through the firewall and hood. Adding insulation would reduce the noise but caution should be exercised to make certain there is sufficient air circulating in the engine compartment to avoid overheating.
Old Apr 5, 2005 | 08:41 AM
Missouri Mule's Avatar
Missouri Mule
The Continentals are indeed crap and they are noisy because they are cheaply made. I am replacing mine at 30,000 miles even though they have substantial tread. I am considering the Hankooks, Firestone and Pirelli but I wouldn't put another set of Continentals on a lawn mower. They are junk.
The heads are aluminum. The valve covers are plastic and this is common throughout the industry. I don't particularly find the engine noise a problem.
rvjoe
Modular V10 (6.8l)
20
Jun 10, 2018 10:27 AM
rustyshakelford
Jun 8, 2018 05:42 PM
Gary Lewis
2015 - 2020 F150
22
May 5, 2017 10:45 AM
theodore/teddy
Feb 1, 2016 09:55 AM
theodore/teddy
Jan 31, 2016 12:47 PM
