reviving an E-350 w/ 351
Old Dec 27, 2020 | 11:03 AM
Robert Kerr's Avatar
Robert Kerr
2nd Gear
I was just given a 1996 E-350 extended Club wagon that my father had in storage for 3 or 4 years.
The battery was dead, and had to replace that to get the odometer reading for the registration transfer (actually it's on the charger, so haven't got the mileage yet..).
I preparation for getting this running, I see that I really should prime the oil-pump prior to turning the motor over. Has anyone done this on an E-350 with the 351 Cleveland motor? is it going to even be possible to get the distributor out without pulling the motor, or am I looking at a massive project to even get the motor running?
Old Dec 27, 2020 | 11:28 AM
Conanski's Avatar
Conanski
It a 351w. It's very likely the in-tank fuel pump will be dead or weak on a truck that sat that long so definitely check fuel pressure. The distributor will come out once you have enough stuff out of the way but you have to put the motor at TDC on cyl #1 first, and then take note of the body and rotor position before pulling it so that it can go back the exact same way.
Old Dec 27, 2020 | 06:46 PM
MoeDaMaster's Avatar
MoeDaMaster
I'd recommend draining and replacing oil w filter as well before trying to crank the engine BY HAND (wrench), NOT USING THE STARTER.
Might be good to blow a whiff of WD40 or just a little engine oil through the Spark Plug Holes into the combustion chambers as well.
Also, check if the brakes are stuck.
There could be a lot of rust in the cooling system as well.
oldford54
Oct 25, 2012 10:07 PM
'83f3fiddy
WTB - Parts & other
Mar 17, 2010 08:00 PM
30dodge
Oct 9, 2009 05:16 AM
Sicpea
North Carolina Chapter
May 4, 2004 07:54 PM
Checycrusher95
Aug 5, 2003 10:55 PM
