Considering a rebuild
Old Dec 27, 2020 | 08:16 PM
Conner Stevenson's Avatar
Conner Stevenson
Originally Posted by z31freakify
So piston rings are good, you might just have weak valve springs, worn valves/valve seats.
Im going to get to pulling the motor and see exactly what’s going on with it here soon. I hope that’s all it is
Old Dec 28, 2020 | 07:31 AM
BBslider001's Avatar
BBslider001
Yeah, at sea level, they definitely should be higher. I was telling you previously because a friend of mine on here had compression numbers that were similar, but he is about 6000 feet. When he did the math, and I forget the formula, his numbers were actually pretty damn good. I was just making sure before you did a huge job that didn't need to be done, but it sounds like you are on the right path. Keep us posted!
Old Dec 28, 2020 | 11:12 AM
Conner Stevenson
I didn’t know that! I appreciate the info! Now if this ever pops up again for someone else on the forum, I can at least start asking the right questions about elevation from someone with the same issue and help them out taking elevation into consideration.
Old Dec 28, 2020 | 02:30 PM
Conner Stevenson
I’m thinking about just ordering a Mabbco long block and throwing it in there and rebuilding my current motor to put in another truck down the road. Has anyone had any experiences with Mabbco?
Old Dec 28, 2020 | 03:19 PM
BBslider001
@oldbird1965 did a Jasper and has had good luck with it. He works his pretty hard too. Maybe he'll chime in.
Old Dec 28, 2020 | 04:48 PM
Conner Stevenson
Thanks! Hopefully I can get some feedback on it before I go in on one!
Old Dec 28, 2020 | 11:05 PM
oldbird1965's Avatar
oldbird1965
Like Byron said, I've had good luck with the Jasper motor. Good people like Byron offered to help me but I was at least 500 miles from his place. I had a hole in piston #8 and the guy at a diesel shop that was recommended to me said it would take a lot longer to rebuild my motor so I just had him get a Jasper. Pulls real hard and I'm happy so far, probably got about 20K on it pulling 18K.
Old Dec 29, 2020 | 10:32 AM
Coralyns97's Avatar
Coralyns97
The previous owner of my truck had a ford reman long block installed part #(f7tz-6v006-barm). A ford dealer in Wyoming did the install.
The first ford engine he had installed threw a rod completely through the block within the first 3k miles. He claimed he was running 160/0 injectors and pushing it pretty hard.
Ford kicked and screamed but honored the warranty and gave home a new 7.3 longblock. The Previous owned had a new turbo installed and 8 new Alliant injectors with this motor
Since i purchased the truck the Ford reman is now at 18k miles and no issues so far
Old Dec 29, 2020 | 01:06 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Weak springs probably explains why my No 8 came up after I did Comp 910s and another reason I tell everyone to do them due to the miles we have and worn seats.
I would also retest with another gauge to verify numbers. Jarrett has a nice unit he may let you bum. Not too sure where you can find a leakdown that may work with the 7.3 DI glow plug hose, unless the HF or OTC (I think Jarrett has) will allow attachment to any universal gauge. I also prefer ones that read to 100...so math is easy in terms of percentage loss.
EDIT - I am not wonder if 6 and 7 being so low, that combustion could even occur.
Old Dec 29, 2020 | 07:33 PM
Conner Stevenson
Im glad to hear that! Definitely going with a reman then!
Old Dec 29, 2020 | 07:35 PM
Conner Stevenson
I wonder what went wrong with the rebuild that caused it to throw a rod that fast! That’s wild! I’m glad to hear the new motor is running smoothly though!
Old Dec 29, 2020 | 07:38 PM
Conner Stevenson
Im curious about 6 & 7 as well! It’s been a real dog and has no power uphill and won’t build past 5-7 psi of boost. I reckon that due to 6&7. I’ll be breaking it down in the coming weeks and seeing what the issues truly are
Old Dec 31, 2020 | 02:19 PM
  #28
Hit Man X's Avatar
Hit Man X
Still have valve covers off?
See if you can spin the valve springs by hand.
Old Dec 31, 2020 | 02:36 PM
  #29
Conner Stevenson
They're still off. I’m going to try and spin them when I get home! I do know that the rocker arms move some on like 6 cylinders though
Old Dec 31, 2020 | 07:53 PM
  #30
97-psd's Avatar
97-psd
There is a chance that Eric is pointing you in the right direction on the valve springs. Without good seat pressure you will get low compression numbers and the other symptoms you are experiencing.
Its not a guaranteed fix but definitely something to check before pulling the motor.
