hmmm...I’ve never heard of this before. I have a stripped vacuum advance port on my carb, I already purchased the heli-coil kit, but I’ll remember this for the future.
I tried greasing the drill bit and tap when I drilled a block for a dipstick tube. (Not Ford) I even put a shop vac nozzle as close as possible to catch even more metal. I had to change the oil pan anyway to a rear sump and glad I did. I was shocked to see how much metal made it into the pan. I even stopped many times to clean, vacuum and re grease along the way. I'll never do it again. Cast iron block.
Timeserts gained popularity with the introduction of aluminum block engines, ala GM Northstar. These engines were notorious for headbolts pulling free from the block. Serious builders would always install timeserts in all the headbolt holes anytime they had the engines down for repair.
I noticed they’re a lot more expensive than hell-coil. My immediate need won’t have stress on the threads (vacuum port) so I’ll stick with what I know for now. Thx for the info.
Yes, use something like a timesert. There are others as well specifically for spark plugs. Some are sold in good auto parts stores. When using a standard heli-coil there is some risk of it screwing in through the spark plug hole and falling into the cylinder when the spark plug is installed.
That doesn't even appear to be a real Heli-coil. I have heard of people winding wire onto the plug threads, it probably worked on low-compression engines.
When I was 17 decades ago a friend of mines mom had a 60s small olds or buick with the aluminum motor that had a cross threaded spark plug he couldn't get to tighten down. He got his impact wrench and pounded that sucker in.He said in the typical fashion of Derek from vice grip garage on you tube,we'll just pretend we didn't see that.It lasted that way for years.Watch vice grip garage if you haven't seen it yet. His dry midwest humor is fun to watch.I didn't know we had you tube on our comcast digital till my granddaughter said grandpa you tell the remote you want you tube and it comes on.
Whenever I suspect something in the cylinder for example the 5.4 spark plugs break off and using the Lyle tool it will cut into the porcelain and some times the electrode will break off. I use a shop vac with adapters to get a small hose into the cyl and after I’ve bore scoped the cylinder I will start the engine with the plug out to blow anything left over out the plug hole.
No it is, it's got the proper cut to it and everything. It was just installed by an ape.
Thankfully the plugs are over the valves and not the piston on this motor but boy howdy. It's a mercy it didn't break off after cycling with the valve for who knows how long.
All the talk about thread repair is technically interesting, but I'll ask a different question. Why not just swap on a different head? Cast iron Ford 8BA heads are cheaper than the more expensive thread options and someone in your area probably has a spare. If you are lucky they also have a spare gasket.
