High idle when warm. Coolant temp sensor?
Old Dec 20, 2020 | 07:19 PM
Rexmortale's Avatar
Rexmortale
Hey guys I have another thread asking about fuel issues. I think I solved that problem and I’ll finish that thread tomorrow after I pull the bed and verify. I have an 89 f150 that’s idling high after warmup only I have replaced the intake manifold gasket, the map sensor, idle air control(fixed high idle after startup), and 02 sensor. I don’t see any issue with the vacuum line, replace the brake booster because that actually had a vacuum leak. I tested the tps at closed throttle and it reads right about .9 volts. I took a Mitty vac to the egr and it holds vacuum and works as far as I can tell. After initial start Up it idles around 1000-1100 then after a minute drops to about 600-750. After about 10 minutes or after driving down the road when I stop and park it it will idle at 1200-1500. It settles around 1500. I read on some other site (now I can’t find it) that the coolant sensor may be bad. The chiltons manual is no help but does anyone know how to proper test the temp sensor on the front of the engine to the pcm? Is there anything else I can check that could be the issue? As far as I can tell I don’t have a vacuum leak.
Old Dec 20, 2020 | 09:42 PM
Bignasty2's Avatar
Bignasty2
Since we're throwing parts at it, make sure you get the sensor with 2 prongs. There's two sensors on these engines and only one sends info to the eec. You could check to see if your idle air control is fouled up as well (Not sure if speed density has these). If you want to eliminate egr as an issue, you could block that off with a plugged fender washer. Keep us posted.
Old Dec 20, 2020 | 10:38 PM
Rexmortale's Avatar
Rexmortale
I already replaced the Iac. I’m trying to stop throwing parts at it. I had a high idle on initial start up when unplugged the iac it would come down. This was when cold. I replaced it along with a Bosch 02 sensor. As I said earlier I have another thread talking about fuel issues which honestly comes down to the PO not installing the fuel pumps correctly(hopefully it’s an easy fix) I replaced the fuel pressure regulator but the intake manifold wasn’t put back on correctly causing a vacuum leak and I thought my map was bad. I fixed that leak when I replaced the gasket to the valve cover. It only idles high after warm up. I’m wondering if there is a way to test the temp sensor with the two prongs before I buy a new one. I tried unplugging it and that didn’t do anything.
Old Dec 20, 2020 | 10:44 PM
yardbird's Avatar
yardbird
I have the resistance readings at different temps on my laptop. I will try to post it up around noon tomorrow.
When you get to warm high idle, try unplugging the temp sensor and see if your idle drops. Mine will.
If you have a 4.9, it's the sensor that's in the pipe coming off the water pump, that connects to the heater hose at the front passenger side of the valve cover.
Old Dec 20, 2020 | 11:07 PM
rexf's Avatar
rexf
if the control valve fixed the high idle after startups check to see if you have engine codes for running too lean or if your simply getting too much air to the combustion chamber. take a quick look around the intake and intake houses for large gaps, holes, or anything that would let too much air in. also check to see if your filter is clean and not damaged.
Old Dec 21, 2020 | 12:25 AM
Rexmortale's Avatar
Rexmortale
That would be awesome! I keep an eye out for it. I tried unplugging it when it started idling high and no change so maybe I’m chasing the wrong thing. I’m taking to a buddies tomorrow to hopefully fix the fuel pumps(again a separate issue) Honestly I’m hoping my fuel delivery may be the issue but if it runs normally before it warms up I think it’s a separate issue.
Old Dec 21, 2020 | 08:45 AM
yardbird's Avatar
yardbird
Here's what I have for coolant temp sensor:
Fuel Injection Technical Library » Engine Coolant Temperature Sensor (ECT)
Here is a chart for intake air sensor:
http://www.fuelinjectedford.com/page29.html
Old Dec 21, 2020 | 09:06 PM
Rexmortale's Avatar
Rexmortale
Thank you all. I’m m not seeing anything out of the normal with the sensor. Buddy of mine sprayed carb cleaner over the intake manifold like I’ve tried in the past and he actually got a result. So I’m going to pull the intake manifold off, again. Try a different gasket with some permatex and hopefully that solves it. It only does it when warm som I’m thinking the heat expansion is making a vacuum leak. Why is it whenever I spray the areas I get no result but when someone else does they get it the first try hahaha.
Old Dec 22, 2020 | 05:28 PM
Rexmortale's Avatar
Rexmortale
Welp
Well I messed up. I figured that maybe I needed to tighten the intake manifold stud to try to fix the leak and I ended up snapping one. Does anyone know the correct replacement for the upper intake manifold studs. Google isn’t much help.
Old Dec 27, 2020 | 01:58 PM
rexf's Avatar
rexf
im not sure of the exact size and width but im sure if you went to a local junkyard and found a vehicle with the same engine you could get one of that and they might not even charge you. also i think you should loosen all the bolts again and re-torque them in the proper steps (if any) and good specs
Old Dec 27, 2020 | 04:07 PM
minimalist's Avatar
minimalist
I Second the junk yard recommendation. Put a new gasket in and use a torque wrench. They don't need much torque.
Mi
Boss_Hogg
18
Jan 21, 2019 06:56 AM
domokdow
Jun 28, 2017 08:23 PM
jdew460
Sep 16, 2016 02:30 PM
chuck641
May 13, 2003 10:50 PM
redtrux
Apr 4, 2003 11:24 PM
