How do I gap my points?
Old Oct 24, 2003 | 02:38 PM
Novice3's Avatar
Novice3
Question How do I gap my points?
I have a F100 With a 360 that I'm trying to tune, But I've never done it before and I can't figure out where to set the gap on my points.
Old Oct 24, 2003 | 02:41 PM
Comegetsome's Avatar
Comegetsome
You can do it with a dwell meter or a feeler gauge.
For a novice, I'd suggest the feeler gauge. Pull the cap of the distributor, and bump the starter until the rubbing block on the points is on a high point of the distributor cam. The points are now open. Insert the correct size feeler gauge between the two contact points and adjust as needed.
Old Oct 24, 2003 | 02:44 PM
Novice3's Avatar
Novice3
I guess my question should have been, does anyone know what the gap measure is?
Old Oct 24, 2003 | 02:47 PM
BB's Avatar
BB
.017"
Comegetsome
68 F100 with a 360? Hmmm...I don't show a listing for such a combination, but 0.017 should work, with a dwell of 24-29, preferably a little closer to 29. I pulled these numbers from the service specs for a '70 with a 360.
Old Oct 24, 2003 | 02:48 PM
Novice3's Avatar
Novice3
Thanx very much.
Old Oct 24, 2003 | 03:28 PM
pward76's Avatar
pward76
no listing for a 68 360?
That's kind of strange, since as I understand it, 68 was the year Ford stopped offerring the 352 in the F100 and the only V8's offerred were the 360 and 390, with the 360 being the more common of the two.
I have also heard that you can use a matchbook cover to gap your points in a pinch
Old Oct 24, 2003 | 03:41 PM
Comegetsome
I'm using a Chilton manual, so it leaves out a lot. It doesn't even list a 352 available past '65, I my '67 used to have one stock.
What can I say, it came with the truck...
As for the matchbook, yes I've done that before and it will at least get you home so you can set them properly.
Old Oct 24, 2003 | 03:43 PM
rrawlins's Avatar
rrawlins
pward76,
When it comes to these old fords...my 69 had the original 352 in it. It also came with power brakes which is unusual as well.
Old Oct 25, 2003 | 12:16 AM
MuchToMyDelight's Avatar
MuchToMyDelight
Have you looked into a modern electronic ignition? Pertronix and Crane make good units that are easier to install than gapping your points. Youll get a bettter running engine, easier starts, and a bump in milage, and best of all, NEVER AGAIN will you wrestle with a set of points.
Old Oct 25, 2003 | 08:48 AM
Kostiuk's Avatar
Kostiuk
I'll second the suggestion for the Pertronix unit. I put one in my truck years ago. It works great and other than two wires coming out of the distributor instead of one you can't even tell it's in there. Points suck. I used to keep a spare set with me and the tools needed to change them and used them on the side of the road more then once.
Old Oct 25, 2003 | 11:15 AM
71_4x4_390's Avatar
71_4x4_390
Dump the points! They are easy to install and you will notice a huge improvement over the point system. I have to ask why people keep a set of points for emergencies. Has anyone has an electronic ignition crap out on them???
Old Oct 25, 2003 | 11:26 AM
Ecuri's Avatar
Ecuri
Also the 75/76 360/390 stock duraspark electronic distributor and module should retrofit to this engine offering a huge improvement over points and perhaps a cost savings versus aftermarket.
Old Oct 28, 2003 | 08:35 PM
baitmaster's Avatar
baitmaster
dinosaur points
Do yourself a favor and spend the $70 for a Pertronix setup. Haven't had my dist cap off for 6 yrs. I used to hang on to the old points, had a whole handful of them. Whether I put the $20 Accels in or a cheap set, it didn't matter. Savin' money now!
