12v Conversion Question
Old Dec 18, 2020 | 11:56 AM
Kempie's Avatar
Kempie
My 51 Mercury M1 was converted to 12v when I purchased it, but there were a number of things that weren’t working so I have been working my way through the wiring and sorting them out one by one. This forum has been incredibly helpful as a guide as I work my way through previous threads, thank you all so much! I am still running a Gen which I expect is 12v and all my lights have been converted, dash gauges have voltage reducers installed BUT I am confused by two things which your previous discussions have prompted me to ask advice. My voltage regulator appears to be 7v ... can this be so? (See first photo) AND I have another device bolted to the firewall which seems to feed the coil, so am wondering if that is a voltage reducer of some sort, and if so do I perhaps have a 6v coil? (See second photo). Thanks for any help.
Old Dec 18, 2020 | 12:25 PM
Brian1950F4's Avatar
Brian1950F4
The second picture should be a ballast resistor to drop voltage to your coil.
Old Dec 18, 2020 | 12:29 PM
51fred's Avatar
51fred
I'd bet that the PO put a new reproduction Label on a 12 volt regulator for looks. The resistor on the firewall is to drop voltage to the points after startup to prevent burning up the points.
Old Dec 18, 2020 | 02:39 PM
Kempie's Avatar
Kempie
Thanks Rich ... would I be able to tell if I took the cover off the regulator?
Old Dec 18, 2020 | 02:45 PM
51fred's Avatar
51fred
There is usually a stamp somewhere on the regulator. It may be on the back side. I would look for that stamp inside or on the back.
If it was running well before, it probably is 12 volt.
Powerstrokin_350
Jul 26, 2019 09:32 AM
bassdr
Jan 26, 2019 12:20 PM
ktgovols
Nov 26, 2015 10:06 AM
52' fordnut
Jul 11, 2015 05:09 PM
CADLAC
1947 and Older Ford Trucks
Oct 21, 2014 10:21 PM
