4wd not working
Dec 20, 2020 | 06:04 AM
sounds to me like the motor at the back of the transfer case is bad.
Next steps to me would be to crawl under there and check it. Pull the wiring connector and ensure it is clean and try again.
then it is probably time for a new motor. You would take it off and see if it actuates disconnected from the transfer case.
Dec 20, 2020 | 12:21 PM
sounds right as the next step. i will also begin shopping for the least expensive motor. thanks again.
Dec 20, 2020 | 03:42 PM
Dec 20, 2020 | 08:15 PM
yes they're on the list i've started along with rock auto, amazon, etc, etc. what about the fact that there is always a whine there as soon as the ign. switch is turned on? i put that in a previous post.
Dec 20, 2020 | 08:22 PM
that is probably due to the motor not working correctly. if you were to just take it off there is not harm in doing so. Just secure the wiring.
Then you can see if the noise is still there too.
Dec 20, 2020 | 08:28 PM
Do you have good vacuum ?... Vacuum leaks ?
Hobo
Dec 20, 2020 | 08:30 PM
Dec 21, 2020 | 09:50 AM
will due soon as i can get on the ground and crawl under. i can only work outside.
Dec 28, 2020 | 04:23 PM
well, no go with a new motor. installed today and have new messages. first, like before, it says 4x4 i process. then, this is new, it says "shift delay- pull forward". i did just that and then it says "check 4x4" and a picture of a wrench. does the same forward or reverse, hi or low range, hubs in or out. so, still no 4x4. ???????
Dec 28, 2020 | 04:26 PM
Dec 28, 2020 | 04:36 PM
i don't have a code reader.
Dec 28, 2020 | 05:24 PM
autozone, O'reily's, advance auto, Napa can all read the codes for free if you take it to them.
Dec 28, 2020 | 05:30 PM
i'll give it a shot. nothing on the dash like a check engine light to indicate.
Dec 28, 2020 | 05:32 PM
but it has the wrench which indicates some kind of powertrain fault.
Dec 28, 2020 | 05:39 PM
hopefully a code will lead to a problem there?
